Summer 2015
So the car was nearly done now yes?
Spotted this under when under the car:
Small oil leak at the turbo
Must have happened when I split it for porting. Didn't think i put it back together correctly.
At this point I could remove the turbo in my sleep so whipped it off and sent it back to BBT.
Turn out it was fine all along.....
The leak was more than likely from an overtightened crush washer. Panic over it was time to put it back on. At the same time I fitted an FSU copper gasket as the standard ones (even when ported like mine) seemed to be blowing on the Pro 4 mani:
Another small mod (to add to my million others) was to change my inlet manifold hose from silicone to alloy.
Why did I do this? I wanted to add a meth port and also increase the size of the hose a little.
Had a few bits of hose and pipe lying around so mocked something up - cut it to shape.
Then had the pipe beaded and the bung welded onto it:
All finished:
And fitted to the car:
Few other finishing touches included fitting some cold air ducting to the brakes and also to the air filter:
The brake duct feed start from the fog lights (long removed) and the air filter from the top grille on the bumper:
I've come up with a better solution for the brake ones which I will show you later...
Since the car was parked up for ages the brake discs were really corroded. Fronts turned out ok after a rub down as they were new before I took the car off the road.
The rears were knackered so swapped them out for a new pair of Pagid discs and pads. Nothing fancy as the rears don't do much and they are cheap from ECP too.
Turns out the passenger rear caliper was a bit sticky and wouldn't wind back. Managed to free it up with a bit of brute force and a long lever:
All done:
Then some new brake fluid, engine and gearbox oil:
MOT'd and taxed and were were back on the road
All finished:
All done:
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
