ibiza k04...gt28rs soon to be (PICS)
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i think the issue maybe with-in the rack. found that a rod end has a small amount of play so gonna try that 1st.
cant see that making the steering light tho...?
if i still get probs wen my old rack is on i will start asking Qs. fingas crossed it sorts it!!??
h17och
Sep 1, 2005
3,504
Dunstabubble
just went for a drive and found that turning left is ok, not too sensitive and quite firm...turning right on the other hand is alot lighter and much more sensitive!?
any ideas, cheers
beattie17
1,353
Perth
things starting to look like they should
Hooch where did you get oil catch tank from?
h17och
Sep 1, 2005
3,504
Dunstabubble
alloy racing fabrication
finally got my car running right...new boost pipe from PA, sort another boost leak and im now soo pleased with it :)
just trying to sort steering.
it seems stiffer when i turn left but feels good at 20mph....40mph+ it goes light when turning right the same when 5mph and less...even at stand still
could it be the pressure switch? anyone know?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Hooch, I had a very similar problem on a Renault. Steering would feel stiff on one side sometimes, then light. Every combination. The dealers said it needed a new rack. I decided I'd get my rack refurbed. I was taking it out when I discovered the inboard joints on the tie rods were knackered. Turned out they were a replaceable part, too.
I think the joint is part of the tie rod on the Ibiza. I'd look for damage on the inner end joint.
Lovely shot of your bonnet, BTW :yes:
h17och
Sep 1, 2005
3,504
Dunstabubble
sorted the problem!!
was incorrect power steering fluid:redface::redface::redface:
i did think at the time i wanted to change it asap but i got carryed away and forgot!
it was a sunday afternoon i think and i wanted to drive it!! lol typical me
thanks for advise tho peeps
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
no idea how this happened but my n75 was in the wrong way round again...? i must have got confused way i was changing it back and forth with my last problem!
so i put it right and im now hitting over 30psi and its popping and backfiring loads. not delivering the power smooth either!?
so im currenlty unning it unplugged to avoid the serious overboosting!
any ideas? is the unsmooth power due to the overboosting?
cheers
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
i didnt think it was running lean from what i remember. really didnt want to drive it much tho. could have a check today!
the only thing ive really thought of is possibly map sensor or map!?!?
HoocH
Ianb
332
Who's mapped the car for you?
What power and torque levels are you running now?
You doing any trackdays?
What FMIC are you using?
h17och
Sep 1, 2005
3,504
Dunstabubble
cc phase 3
not sure on power...not enuff as its not running right
if i keep it i will be tracking it
fmic...pro alloy large core
