ibiza k04...gt28rs soon to be (PICS)
myk3
Newbie
Dec 16, 2005
304
just remove the arm, then screw it to loosen it a turn at a time and test.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
just logged actual vs actual boost
im seeing 2300 mBAR requested!!!
why would it be doing this? does it just need boost turning down on map?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
yes, and subtract atmospheric pressure from this number and you get actual +ve pressure (gauge)
like m0rk says 1.3bar
no biggie there is there
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
what's the delivered boost tracking like? sensor reading correctly? w/gate doing what it's meant to do? pipes connected correctly?
h17och
Sep 1, 2005
3,504
Dunstabubble
oh, i thought that was 2.3 bar!?!?
so thats ok then?
im seeing 30+psi on guage, actual was about 2200mbar i think, will go check!
all connected correctly now, as far as im aware
how do i know if wastgate is doing what its ment to?
h17och
Sep 1, 2005
3,504
Dunstabubble
could this be due to my wastegate not opening enough then? maybe my actuator needs extending?
ive yet to play with the adjustment...wanted to log 1st!
is there any other blocks i should log 1st?
h17och
Sep 1, 2005
3,504
Dunstabubble
this is the bit of logging i did but its not great as it runs awful and i dont want to boot it too much
i stopped it twice during logging hence the random figures
Code:
Tuesday,04,September,2007,19:36:44
6K0 906 032 AA,,1.8L 20VT EU3       0002,
,Group A:,'115,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Load,Absolute Pres.,Absolute Pres.,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
Marker,STAMP, /min, %, mbar, mbar,STAMP,,,,,STAMP,,,,
,0.01,1440,59.4,1040.0,1040.0,,,,,,,,,,
,0.25,1480,77.4,1180.0,1050.0,,,,,,,,,,
,0.55,1480,79.7,1280.0,1060.0,,,,,,,,,,
,0.85,1520,80.5,1360.0,1080.0,,,,,,,,,,
,1.15,1520,83.5,1420.0,1090.0,,,,,,,,,,
,1.45,1560,86.5,1440.0,1100.0,,,,,,,,,,
,1.75,1600,89.5,1460.0,1110.0,,,,,,,,,,
,2.05,1640,91.0,1500.0,1120.0,,,,,,,,,,
,2.35,1640,91.7,1540.0,1130.0,,,,,,,,,,
,2.65,1680,91.7,1590.0,1140.0,,,,,,,,,,
,2.95,1720,91.7,1630.0,1150.0,,,,,,,,,,
,3.25,1760,91.0,1640.0,1160.0,,,,,,,,,,
,3.55,1760,92.5,1660.0,1160.0,,,,,,,,,,
,3.85,1800,92.5,1670.0,1170.0,,,,,,,,,,
,4.15,1840,92.5,1700.0,1180.0,,,,,,,,,,
,4.45,1880,93.2,1740.0,1180.0,,,,,,,,,,
,4.75,1920,93.2,1760.0,1190.0,,,,,,,,,,
,5.05,1960,94.0,1800.0,1200.0,,,,,,,,,,
,5.35,2000,96.2,1850.0,1210.0,,,,,,,,,,
,5.65,2040,97.7,1850.0,1230.0,,,,,,,,,,
,5.95,2080,100.0,1850.0,1240.0,,,,,,,,,,
,6.24,2120,103.0,1850.0,1260.0,,,,,,,,,,
,6.55,2160,103.8,1850.0,1280.0,,,,,,,,,,
,6.85,2200,106.0,1860.0,1300.0,,,,,,,,,,
,7.15,2280,106.8,1860.0,1320.0,,,,,,,,,,
,7.45,2320,108.3,1860.0,1340.0,,,,,,,,,,
,7.75,2400,109.0,1900.0,1370.0,,,,,,,,,,
,8.05,2440,109.8,1900.0,1390.0,,,,,,,,,,
,8.35,2520,111.3,1910.0,1400.0,,,,,,,,,,
,8.65,2560,111.3,1910.0,1420.0,,,,,,,,,,
,8.95,2640,112.8,1930.0,1440.0,,,,,,,,,,
,9.24,2680,113.5,1930.0,1460.0,,,,,,,,,,
,9.55,2760,115.0,1920.0,1470.0,,,,,,,,,,
,9.85,2840,115.8,1930.0,1480.0,,,,,,,,,,
,10.14,2880,116.5,1940.0,1490.0,,,,,,,,,,
,10.44,2960,117.3,1930.0,1500.0,,,,,,,,,,
,10.74,3000,118.8,1920.0,1500.0,,,,,,,,,,
,11.04,3080,121.1,1940.0,1530.0,,,,,,,,,,
,11.34,3160,124.1,1920.0,1550.0,,,,,,,,,,
,11.64,3240,130.1,1920.0,1590.0,,,,,,,,,,
,11.94,3280,135.3,1860.0,1650.0,,,,,,,,,,
,12.24,3360,142.9,1720.0,1720.0,,,,,,,,,,
,12.55,3480,149.6,1620.0,1820.0,,,,,,,,,,
,12.85,3560,157.1,1480.0,1930.0,,,,,,,,,,
,13.15,3600,135.3,1270.0,1890.0,,,,,,,,,,
,13.45,3600,43.6,1000.0,1580.0,,,,,,,,,,
,13.75,3600,25.6,1000.0,1280.0,,,,,,,,,,
,14.05,3520,18.0,1000.0,1160.0,,,,,,,,,,
,14.34,3440,18.0,1000.0,1100.0,,,,,,,,,,
,14.64,3360,14.3,1000.0,1080.0,,,,,,,,,,
,14.94,3400,15.0,1000.0,1060.0,,,,,,,,,,
,15.25,3360,53.4,1150.0,1030.0,,,,,,,,,,
,15.55,3400,85.7,1310.0,1080.0,,,,,,,,,,
,15.84,3440,91.7,1280.0,1170.0,,,,,,,,,,
,16.15,3480,99.2,1280.0,1280.0,,,,,,,,,,
,16.44,3520,97.7,1220.0,1400.0,,,,,,,,,,
,16.75,3560,89.5,1390.0,1470.0,,,,,,,,,,
,17.04,3640,124.1,1600.0,1470.0,,,,,,,,,,
,17.35,3680,139.1,2140.0,1630.0,,,,,,,,,,
,17.64,3760,154.1,2280.0,1810.0,,,,,,,,,,
,17.95,3880,175.2,2290.0,2030.0,,,,,,,,,,
,18.24,3960,191.7,2310.0,2300.0,,,,,,,,,,
,18.55,4040,191.7,2310.0,2530.0,,,,,,,,,,
,18.85,4120,191.7,2310.0,2540.0,,,,,,,,,,
,19.14,4160,191.7,1880.0,2540.0,,,,,,,,,,
,19.44,4000,62.4,1000.0,2070.0,,,,,,,,,,
,19.75,3480,41.4,1000.0,1400.0,,,,,,,,,,
,20.04,2960,20.3,1000.0,1210.0,,,,,,,,,,
,20.34,2520,13.5,1000.0,1120.0,,,,,,,,,,
,20.64,3240,12.8,1000.0,1080.0,,,,,,,,,,
,20.95,3280,12.0,1000.0,1060.0,,,,,,,,,,
,21.24,3240,12.8,1000.0,1050.0,,,,,,,,,,
,21.54,3240,12.0,1000.0,1050.0,,,,,,,,,,
,21.84,3240,10.5,1000.0,1040.0,,,,,,,,,,
,22.14,3200,9.8,1000.0,1040.0,,,,,,,,,,
,22.44,3160,6.8,1000.0,1030.0,,,,,,,,,,
,22.74,3160,7.5,1000.0,1030.0,,,,,,,,,,
,23.04,3160,7.5,1000.0,1030.0,,,,,,,,,,
,23.34,3120,6.8,1000.0,1030.0,,,,,,,,,,
,23.64,3120,6.8,1000.0,1030.0,,,,,,,,,,
,23.94,3080,6.8,1000.0,1020.0,,,,,,,,,,
,24.24,3080,7.5,1000.0,1020.0,,,,,,,,,,
,24.54,3040,6.8,1000.0,1020.0,,,,,,,,,,
,24.84,3040,8.3,1000.0,1020.0,,,,,,,,,,
,97.51,3240,100.0,1590.0,1220.0,,,,,,,,,,
,97.80,3240,109.8,1650.0,1310.0,,,,,,,,,,
,98.11,3280,117.3,1680.0,1410.0,,,,,,,,,,
,98.40,3320,126.3,1820.0,1510.0,,,,,,,,,,
,98.70,3360,134.6,1960.0,1610.0,,,,,,,,,,
,99.01,3400,142.9,2210.0,1720.0,,,,,,,,,,
,99.30,3480,151.9,2210.0,1820.0,,,,,,,,,,
,99.60,3520,159.4,2220.0,1930.0,,,,,,,,,,
,99.91,3560,170.7,2220.0,2060.0,,,,,,,,,,
,100.20,3640,182.7,2230.0,2210.0,,,,,,,,,,
,100.51,3680,191.7,2240.0,2400.0,,,,,,,,,,
,100.80,3720,164.7,1570.0,2540.0,,,,,,,,,,
,101.11,3600,77.4,1000.0,1920.0,,,,,,,,,,
,101.40,3680,33.1,1000.0,1380.0,,,,,,,,,,
,101.71,3640,18.0,1000.0,1190.0,,,,,,,,,,
,102.01,3640,14.3,1000.0,1120.0,,,,,,,,,,
,102.30,3640,12.0,1000.0,1090.0,,,,,,,,,,
,102.60,3600,12.8,1000.0,1070.0,,,,,,,,,,
,102.90,3560,10.5,1000.0,1060.0,,,,,,,,,,
,103.20,3560,9.8,1000.0,1050.0,,,,,,,,,,
,103.50,3520,9.0,1000.0,1040.0,,,,,,,,,,
,103.80,3520,7.5,1000.0,1040.0,,,,,,,,,,
h17och
Sep 1, 2005
3,504
Dunstabubble
from what i can work out, my actual boost on vag com is dfferent to what im seeing on boost guage (I THINK)
anyone got any ideas?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
that doesn't mean it's not working though......
scaled MAP sensor in the ECU
as Bill pointed out, and you've so far ignored - unless it's all the same stuff (not similar stuff) then it's hard to draw comparisons against someone elses setup.
if the MAP is reading differently to your boost guage, one of them is wrong.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
MAP sensor if std one is 2550mb max, so wont read anything higher.
Mines still running like this but runs an actual boost level higher... as thats how its been set by CC for me.
I would rather run 3bar map sensor personally to see actual boost, but my control is apexi these days, and my mappings well hacked to work with my spec, so not really comparitive to road car.
logging n75 to see if its trying (but failing) to pull back duty cycle to lower boost, but maybe failing.
What could be happening is boost creep, which is wastegate failing to bleed out excess pressure/flow, hence it runs away once spooled no matter what you do to try and control.
Trying to diagnose via forum is impossible however.. We dont know the full story and you have clearly been trying and changing all sorts of things.
h17och
Sep 1, 2005
3,504
Dunstabubble
mork ive not ignored it just been trying to work out what else may have been different! so far ive yet to find anything!
yea its standard map sensor and spoke to jbs and they said its been mapped to run standard one!
any way of testing the actuator if its boost creeping?
thanks for the help guys, im sure your fed up of helping me now...its all much appreicated tho :):) ;);)
