Another log im afraid, but its looking a little better
Actuator tweaked a further 1.5mm (19.5mm) as opposed to 17mm standard. This log is a 4th gear run......
3160...94.9%...2540
3560...94.5%...2540
4000...91.8%...2540
4360...86.3%...2540
4720...78.8%...2540
5040...78.8%...2370
5280...81.6%...2260
5560...93.3%...2240
5760...88.6%...2160
5960...90.2%...2170
6160...86.3%...2170
6320...84.3%...2170
6480...84.3%...2050
6600...78%......2180
6700...71%......2230
Fully spooled at 1.8bar at 3160rpm and falling to 1.55bar at 4720rpm so it is boosting beyond MAP capabilities for 1500rpm in this low down range. On my logs before, the range was only about 700rpm above MAP capability, now its double that at about 1600rpm.
It does give a good kick in the back and pulls very well. Unfortunately i cant show the fall between 1.8bar and 1.55 bar due to vagcom not recognising these values.
Then it goes all too familiar again between 5000-6000rpm and im not too sure whats happening at 6480rpm and above, it seems to go very low at 1.05bar, and then bounces back to 1.18bar, and then 1.23bar. (Boost creep anyone
1.25bar or thereabouts is what Sie is achieving on his at this rpm so not too far away at all.
4th gear nitrous run... I didn't think it would effect turbo flow though as its injected just before it goes into inlet mani, and nothing to do with turbo
3500....2540
4120....2540
4800....2450
5400....2320
5920....2320
6320....2230
6750....2200
5920rpm in 4th (nos) =2320 =1.32bar
5960rpm in 4th =2170 =1.17bar
It shows you how quick the nitrous makes it though, as there is 14 time markers in my ordinary 4th gear run and only 7 markers above in the same rpm range (3500-6750)
I'm noticing now and again requested values at set rpm's are different
On 1 log ive got a requested value of 2280mbar @ 5560rpm and on another log ive got a requested value of 2340mbar @5560rpm.
Very strange as no adjustments to software have been made
