It's taken some time to get there, was it just the fuelling? I see your Stage 3 APR Post, I think that's the way to go, if not, see what Bill will do (if he's not too nervous to push an unknow tubby).
If it's anything like Sie's was, I bet it drives really nice.
Rome wasn't built in a day
but i do need to speed up my modding process if i'm to finish the car before the world runs out of petrol.
My current APR map is perfect in nearly all ways, fueling is excellent with a 4 bar reg (not exceeding 90% injector duty cycle) and a few tweaks with lemiwinks ( main fueling reduced by 11%), 0.83 lamda under WOT.
I have two issues with boost control however. To increase boost using V tune i increase the boost request by 10% say, which increase requested boost at the red line to 1.45 bar but it does so linerly across the rev range which causes requested boost mid rev range to exceed 2550 mb. This is pants because my map sensor will only ever reach 2540mb and so the map never reaches its requested boost values and so boosts uncontrolled until the boost rquested by the map drops below 2540mb, i overcome this with a mbc connected in parallel with the n75 valve but its not ideal.
The second boost issue i have is n75 duty cycle and actuator spring pressure related.
Because the hybrid is compressor heavy compared to a stock tubby, the 6 psi actuator doesn't even produce stock tubby performance levels, so i upgraded to a forge uprated actuator with a 10psi (measured) spring tension. This is great and produces the goods but does occasionally cause overboost/limp issues in 5th gear on rolling roads etc and is very annoying. Its that 200mb difference between requested and achieved that cause the ecu to throw a limp mode which most stage 2 software still keeps but appears to be missing in most stage 3 codes.
