Never timed myself! But felt quicker! My suspension setup was much better than previous efforts on standard. Which is probably where I made most of my time up, especially around the old hair pin!
Yeah its the sodding T3 sensor again!
Thats what was on there, the thread must be shafted on the sensor side i think
225 g/s with my hybrid max. That was on a cold night also.
Saying that i do believe if you de screen the MAF it does read higher. Martins standard K04 reading 225g/s for instance.
I would suspect his maf if his is reading 235g/s. Something dodgy going on there or he has a different turbo in it![]()
I do believe anything under 14 degrees timing pull is safe as thats what the ecu can compensate for.
IHI is only 245g/s is it not?
Sie's MAF only reads about 180ish but he has a larger MAF in there and i believe scottys is similar to mine around the 225 mark.
Didn’t a certain tuner allegedly play with maf readings?
James at CC told me the ECU can compensate for upto 14degrees timing pull. To me surely that means the pull is within limits of capability and is not going beyond its safe limits?
I say over reading as im using martins thread about 2 months ago with his readings of 225 as a reference. Im sure de-screening the MAF messes up the airflow readings??
225 means around 300bhp with the normal calculations, but his car only produced 265-270bhp when tested. Maf figures didn't correspond to the power figures he was getting.
The same 265-270bhp figure was being produced with much lower maf figures of 200-210 on other cars
Either that or there is no link at all between maf figures and power outputs?
0.91 isn't overly lean is it, or did his readings not go below this at all? Again i thought anything over 1.0 was dangerous?
I know CC mapping compared to jabba mapping is very safe. The fuelling stays rich throughout and im sure that effects overall performance? I personally think their mapping is too conservative and safe. As you'll probably know jabba maps run quite lean, however i was mapped with them over 2 years and it had never done my engine any harm![]()
If airflow logging was linked to bhp figure output then i would assume his k04 turbo at 235g/s was running around 310bhp which of course is not possible.
So i personally think x g/s = x bhp is a lot of bollocks![]()
Hs it had any other mods? De screened MAF etc?
Hes not bought our Turbo has he!![]()
