Carl...
In 6th gear, so lots of measurements due to the increased time in gear, but will give you an idea of the whole turbo range. Well as far as i managed lol, 6th gear at these kind of revs is well, you know
3760 = 2490/2540 = 95.7%
3880 = 2480/2540 = 92.5%
4040 = 2490/2540 = 89.4%
4200 = 2480/2540 = 85.9%
4320 = 2470/2540 = 81.6%
4440 = 2450/2540 = 78.8%
(Turbo producing over 1.55bar boost for 700rpm. That is 1.8bar falling to 1.55bar in that time according to boost gauge. Obviously cant get more accurate results as MAP sensor limited)
4520 = 2430/2490 = 77.6%
4640 = 2410/2410 = 78%
4720 = 2420/2420 = 78.4%
4840 = 2410/2410 = 79.2%
4920 = 2410/2410 = 80%
5080 = 2390/2390 = 86.7%
5160 = 2390/2390 = 92.5%
As you can see upto 5160rpm actual is meeting requested all the way, with ease. Wastegate not maxxed. Now the turbo begins struggling to meet requested and wastegate is working harder to try and achieve this....
5200 = 2390/2300 = 94.9%
5280 = 2380/2310 = 94.1%
5320 = 2360/2310 = 92.2%
5400 = 2350/2260 = 93.7%
5440 = 2360/2250 = 98%
5480 = 2360/2260 = 100%
5520 = 2340/2220 = 91%
5600 = 2330/2220 = 95.3%
5720 = 2280/2180 = 100%
5800 = 2250/2210 = 100%
5840 = 2250/2190 = 95.7%
5920 = 2250/2110 = 100%
6020 = 2220/2150 = 98.7%
OAT was 11c and IAT max when i come off the throttle above at 6020 rpm was 40c, even with FMIC
On 4th gear runs, ive never seen it above 28c
And then thats as far as i went as i was going pretty quick at this time and everything was getting hot,hot,hot! Oil temp now around at 150c so had to back off for a while.
Gives you an indication of what the turbo and wastegate are doing to achieve boost. Upto 5160rpm, the turbo is clearly not maxxed and has more left to give. However after this, it starts struggling even with nearly maxxing wastegate to achieve requested values.
