hybrid boost logs
Jul 4, 2010
2,170
Cambs
It doesnt really matter what it "should" be running mate.. as long as its making decent power & doesnt pull high cf's :D
If your airflow is being utilized I dont think you will make much more without wmi.
Jul 4, 2007
1,674
bristol
It sure does fly! I'll phone em tomorrow and book a dyno.
I think your right I have maxed this setup out without Wmi. Next step bt lol one day, one day
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
group 003 for you bill
Code:
	Group A:	'003				Group B:	 Not Running				Group C:	 Not Running
		RPM	Mass Flow	Load	Ign. Timing
	TIME					TIME					TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP					STAMP
	250.13	1640	36.64	100	0.8
	250.53	1760	39.94	100	0.8
	250.93	1840	42.53	100	0.8
	251.33	1960	48.58	100	2.3
	251.73	2080	61.61	100	2.3
	252.23	2240	74.22	100	2.3
	252.73	2440	89.61	100	1.5
	253.13	2640	101.11	100	0.8
	253.53	2840	118.86	100	1.5
	253.93	3120	146.31	100	3.8
	254.33	3360	139.94	100	4.5
	254.74	3640	162.44	100	3
	255.13	3880	175.94	100	3
	255.53	4080	175.28	100	3
	255.94	4320	180.69	100	3
	256.34	4520	178.64	100	3.8
	256.74	4680	185.78	100	3.8
	257.14	4880	186.25	100	3.8
	257.54	5040	193.69	100	3.8
	257.94	5200	195.97	99.2	4.5
	258.44	5360	200.86	100	4.5
	258.84	5520	200.06	100	3.8
	259.24	5680	205.86	100	3
	259.64	5760	210.33	100	3.8
	260.04	5880	215.31	100	3.8
	260.44	6000	216.39	100	4.5
	260.84	6120	218.56	100	3.8
	261.33	6280	217.08	100	3.8
that is low overall timing.. but clearly all your engine wants (forged pistons yea?)
maybe slightly noiser engine mechanically which is what is setting the knock sensors going)
wild willy
2,323
Wales
Bill,
what would you consider good timing advance or acceptable timing advance for a hybrid or any other tuned car without wmi, provided the cf's aren't excessive. I think i recall seeing 15's on mine at the red line.
Jul 4, 2007
1,674
bristol
Cheers bill I think your right it's all it want and yer 1.9 forged je pistons. So would make sense that it's noisier cars making good g/s and feels rapid. So I shouldn't worry
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Bill,
on smallport (or ported smallport) low to mid teens in timing at 6krpm seem "normal"
largeports, we can run higher to 24 degrees and low teens under boost, where smallports dip into single digit timing usually @ same rpm/boost
Jul 4, 2010
2,170
Cambs
Bill are you saying that its noisier becuase of the pistons, or its noisier becuase it has been rebuilt.
I find it very hard to believe that the pistons alone are playing havoc with the knock sensors.. after all the standard items are forged..
We found out that cylinder 1 & 2's knock sensor was actually in the wrong boss and torqued incorrectly with paint on the boss face, but Joe sorted this out and still it made hardly any difference.
Joe do you know if all the tollerences were checked when it got rebuilt?
Jul 4, 2007
1,674
bristol
Yer cam to cam timing was all spot on.
The only thing I can think is one knock sensor had brown plug the other black maybe new ones would fix this.
My only worry is if I ever go bt I will have issue with making crap power
Hybrid is ok maxed out really
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
rebores are subject to the machining tolerance, and the likes of JE's for example are bigger clearances than stock pistons.. so some more "noise" is possible.
Same goes for uprated engine mounts coupling engine vibration into the knock sensors which is interpreted as "knock" when its vibration noise. Had this in an extreme example on an R32 turbo I dyno'd a couple of weeks ago. Horrendous CF of 15's.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you are making normal power for hybrid tho. Pretty good in fact without wmi on board.
smallports imho suk when it comes to decent timing... even ported ones wont support what boggo largeports will by some big margin.
another hybrid ibiza, same turbo, but running wmi on it
Code:
Group A:	'003				Group B:	'020				Group C:	'118
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Temperature	Load	Absolute Pres.
TIME					TIME					TIME
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	°C	 %	 mbar
65.02	1640	18.25	12.9	23.3	65.43	3	5.3	6	0.8	65.83	1640	17	90.6	1110
66.23	1680	25.97	100	18	66.63	0.8	3	5.3	0	67.04	1680	18	95.3	1220
67.44	1800	30.25	99.6	9	67.82	0	2.3	3.8	0	68.24	2200	18	95.3	1380
68.63	2400	53.58	100	12	69.02	0	2.3	3	0	69.42	2840	16	92.9	1970
69.81	3120	111.53	99.6	9.8	70.25	0	1.5	3.8	0	70.62	3600	17	70.6	2440
70.92	3760	127.36	99.6	13.5	71.35	0	1.5	3.8	0	71.75	4200	16	64.3	2410
72.13	4400	149.31	100	17.3	72.53	0	0.8	3.8	0	72.95	4760	17	59.2	2300
73.33	4920	174.83	100	18.8	73.71	0	0.8	3.8	0	74.04	5240	18	57.3	2310
74.41	5400	184.31	99.6	15.8	74.74	0	0.8	3.8	0	75.11	5640	19	57.6	2200
75.41	5760	186.61	100	17.3	75.72	0	0.8	3.8	0	76.14	6040	21	95.3	2210
76.54	6160	200.39	100	16.5	76.96	0	0.8	3	0	77.36	6440	23	95.3	2150
77.74	6560	204.56	100	17.3	78.12	0	0.8	3	0	78.53	6800	24	95.3	2140
78.96	6960	203.78	100	21	79.36	0	0	3	0	79.74	6520	23	0	1860
1,674
bristol
cheers bill makes me feel a bit better as that ones making less g/s but as i cant see 17 around 6kish high timing. mines like 4 lol
im really happy with what ive got thats me done for hybrids i love it when im bored going bt one day.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
this hybrid made 280bhp with its additional timing from wmi tweaks
