Greesha's - imperial blue cupra
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
Nice to meet you again tonight mate
As promised here are the logs
I would diagnose it as a definite boost leak, with it shooting rom 1.3bar, down to just over 1bar etc then back up again
although oddly enough, it appears to be meeting requested, but requested at 1.1bar is quite a tame map:confused:
I couldnt spot any loose pipes straight away also
and thanks for the Polish beers, I look forward to those this weekend! :cheers:
I hope you enjoyed the ride in the car....since then I have a turbo whistle and a loose pipe somewhere :lol:
RUN 1
Code:
Group A:	'002				Group B:	'115
	Idle speed	Engine load	Inj. period	Air mass in		Engine Speed	Engine Load	Spec. Boost	Actual Boost
TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s	TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
STAMP	 /min	%	 ms	 g/s	STAMP	 /min	%	 mbar	 mbar
0	1920	104.5	11.22	40.75	0.4	2000	110.5	2060	1390
0.8	2080	114.3	12.24	47.22	1.2	2120	118.8	2060	1510
1.71	2200	123.3	13.6	52.56	2.11	2280	127.8	2080	1650
2.51	2400	134.6	15.64	62.92	3.01	2520	151.1	2130	1840
3.41	2600	160.2	18.36	82.72	3.82	2720	166.2	2140	2080
4.22	2840	174.4	20.4	96.89	4.62	2960	182.7	2160	2230
5.02	3080	174.4	20.74	97.06	5.42	3200	165.4	2120	2070
5.82	3320	173.7	20.74	111.31	6.24	3400	171.4	2070	2090
6.73	3560	168.4	20.74	113.69	7.13	3680	166.2	2080	2030
7.53	3760	171.4	21.42	125.19	7.93	3880	172.2	2100	2110
8.35	4000	172.9	21.42	134.08	8.75	4120	175.9	2100	2160
9.15	4200	170.7	21.08	136.47	9.55	4320	171.4	2070	2050
9.95	4440	175.2	21.76	146.67	10.46	4560	173.7	2030	1980
10.86	4680	172.2	21.42	153.83	11.26	4800	171.4	1990	1950
11.66	4880	168.4	22.1	158.03	12.06	4960	166.9	1960	1930
12.57	5080	166.9	23.12	163.39	13.09	5200	166.9	1950	1930
13.47	5280	165.4	23.12	165.78	13.89	5360	166.2	1940	1920
14.29	5480	163.2	23.46	171.86	14.68	5560	163.2	1930	1910
15.08	5640	163.9	24.14	176.36	15.48	5720	161.7	1900	1920
15.9	5800	160.2	24.14	177.97	16.3	5880	157.1	1850	1900
16.7	5960	148.9	22.78	166.25	17.08	6000	138.3	1630	1650
17.5	6080	136.1	19.72	158.42	18.01	6120	136.1	1610	1610
18.51	6200	132.3	19.04	156.39	18.91	6240	135.3	1600	1590
19.31	6280	131.6	19.04	159.69	19.72	6320	131.6	1600	1610
20.12	6360	130.1	18.7	158.67	20.62	6400	116.5	990	1740
21.02	5760	10.5	1.7	11.97	21.42	5120	12	990	1080
21.82	4480	12.8	0	9.56	22.22	4120	12	990	1040
22.62	4000	12	0	8.39	23.02	3920	12	990	1040
23.44	3800	12	0	8.44	23.84	3680	12	990	1030
RUN 2
Code:
0.59	2040	91.7	11.22	39.83	1.01	2080	104.5	2060	1290
1.41	2160	114.3	11.9	50.5	1.9	2280	124.8	2080	1560
2.3	2360	133.8	15.3	63.75	2.7	2480	148.1	2130	1810
3.12	2600	162.4	18.7	82.28	3.52	2720	170.7	2150	2090
3.92	2880	178.2	20.06	100.89	4.32	3000	190.2	2170	2320
4.72	3160	171.4	19.38	99.25	5.23	3320	168.4	2100	2060
5.73	3480	172.2	20.4	114.83	6.13	3600	170.7	2060	2060
6.53	3720	171.4	20.74	123.28	6.93	3840	169.2	2090	2050
7.34	4000	172.9	20.74	135.92	7.74	4120	178.9	2100	2180
8.14	4240	171.4	20.74	137.47	8.54	4360	173.7	2070	2040
8.94	4480	177.4	21.42	151.69	9.34	4600	173.7	2030	2030
9.74	4720	168.4	20.4	149.69	10.16	4840	171.4	1990	2040
10.65	4960	168.4	21.76	158.64	11.05	5080	166.9	1950	1940
11.47	5160	166.2	21.08	162.53	11.87	5280	165.4	1940	1930
12.37	5400	166.2	23.46	169.42	12.77	5480	164.7	1930	1920
13.17	5560	163.9	23.46	174.08	13.57	5680	163.9	1910	1900
13.98	5760	162.4	23.8	177.08	14.49	5840	157.9	1880	1890
14.97	5960	160.2	24.48	178.17	15.39	6040	150.4	1710	1810
15.88	6120	136.1	20.4	158.67	16.3	6160	136.1	1630	1660
16.7	6200	136.8	20.06	162	17.2	6280	134.6	1600	1630
17.6	6320	133.8	19.38	162.28	18.01	6480	25.6	980	1670
18.49	5600	12	2.04	11.72	18.91	5080	124.8	1970	1380
RUN 3
Code:
Group A:	'004				Group B:	'023
	Idle speed	ECM Voltage	Coolant Temp	Intake Temp		Engine Speed	Engine Load	Tim. Retard 3	Tim. Retard 4
TIME	700-820 rpm	12-15V	80-110 C	-48-110C	TIME	700-6800 RPM	15-150%	0.75-12 KW	0.75-12 KW
STAMP	 /min	 V	°C	°C	STAMP	 /min	%	 CF	 CF
0.49	1800	13.72	90	21	0	1800	12	0	0
1.38	1160	13.72	90	23	0.89	1560	12.8	0	0
2.2	1840	13.72	90	21	1.8	1720	81.2	0	0
3	2000	13.51	90	18	2.6	1920	99.2	0	0
3.8	2160	13.65	90	16	3.4	2080	113.5	0	0
4.61	2320	13.65	90	15	4.21	2240	122.6	0	0
5.41	2560	13.65	90	15	5.01	2440	137.6	0	0
6.21	2800	13.65	90	15	5.81	2640	160.9	0	0
7.12	3080	13.65	90	15	6.63	2920	178.2	0	0
7.92	3360	13.65	90	15	7.52	3240	172.2	0	0
8.74	3600	13.65	90	17	8.32	3480	170.7	0	0
9.54	3880	13.65	90	18	9.14	3760	169.9	0	0
10.34	4120	13.65	90	19	9.94	4000	175.2	0	0
11.35	4440	13.58	90	21	10.85	4280	172.9	0	0
12.16	4680	13.65	90	21	11.75	4560	172.2	0	0
13.06	4880	13.58	90	23	12.66	4800	169.2	0	0
13.86	5120	13.65	89	24	13.46	5000	168.4	0	0
14.66	5280	13.65	89	24	14.28	5200	166.2	0	0
15.48	5480	13.65	89	26	15.08	5360	165.4	0	0
16.29	5640	13.65	89	27	15.89	5560	166.2	0	0
17.19	5840	13.72	89	27	16.77	5760	160.9	0	0
18	6000	13.65	89	28	17.59	5920	157.1	0	0
18.9	6120	13.65	88	27	18.5	6080	133.8	0	0
19.91	6240	13.65	89	27	19.41	6200	131.6	0	0
20.82	6360	13.65	88	27	20.31	6320	131.6	0	0
21.71	5240	13.79	88	24	21.31	5920	10.5	0	0
22.61	4120	13.65	88	24	22.21	4480	12	0	0
23.41	4000	13.72	88	24	23.01	4080	12	0	0
Thanks for logging tonight Tony ! It was nice seeing you as well.
Yes. I'm undoing everything tomorrow and I will try to re tighten all the hoses and clamps. Too bad i cant really think which one may be causing this.
Yours was damn fast ^^ all the rev range on every gear - impressive :D
haha sorry for the boost leak - i guess im cursed !
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Greesha glad that you decided to go with that FMIC kit and the honeycomb grille, you've fitted them very nicely, very unusual to see that setup on a pre facelift bumper. Really smart :)
I hope you get the underboost sorted, strangely I have got mine booked in on Thursday for Will @ P Torque to look at leaking boost on mine, it goes to 19 psi then drops to about 12, mpg is pretty bad :( Still managed to blow a 225 TT away though the other day ha
greesha
Jan 6, 2009
496
Slough
Kineticz i must say i like this setup a lot on prefacelift bumper hehe. Hope you get your leaks sorted!
I've redone all the clamps on my IC setup and took it for a spin. Still felt weak. As i had no more ideas i bought new MAP sensor and i think it has sorted my car out. I can definitely feel the power - still not sure if its 100% healthy but feels better !
jamiebennett81
Let's log t confim
however the good ol butt dyno will tell us :)
greesha
Jan 6, 2009
496
Slough
It would be cool to do those logs that Bill was asking about. :D
Have you sorted your car Tony ?
jamiebennett81
Will do two runs per set of logs
not yet, pissing down with rain all day! Will investigate on Thursday
mattdavies
Pre-Facelift Bumpers FTW
Jan 24, 2009
88
Maidenhead
Saw you last night in slough, you were the other side of the A4 near the three tuns. Looks good im hoping i can sort something out and work then will be able to come tomorrow.
greesha
Jan 6, 2009
496
Slough
Maybe its me but i think it feels weaker. We we will see tomorrow on AMD RR day :p. But if its not running well then i have no idea how to sort it out. I'm 120% sure that all clamps are tight. Maybe n75 got damaged during install? No idea. Maybe tomorrow somebody will advise me something if it won't run proper power.
greesha
Jan 6, 2009
496
Slough
Cupra badge added on front grill :D - I think it looks great
EDIT:
No time to clean my car for AMD RR day as i work 13 hours today... :<
mattdavies
Jan 24, 2009
88
Maidenhead
Looks really good, did you have to modify anything to get the grill to fit, if so what ?
Spend hours today fitting intercooler on mates ibiza, what a mission most the time spent modifying his bumper !!
greesha
Jan 6, 2009
496
Slough
Latest AMD RR day graph
Well quite ok. Its just a stage 1 remap after all. Although i'm quite disappointed in torque loss. I guess that's why i have this strange feeling that car doesn't pull like it used to :<
Can it be caused by FMIC install? Map doesnt work very well with larger IC ? No idea.
Its 230/220 lb/ft now - it was 241 on totally standard car (even on plastic DV) :p
225 hp is rather optimistic as well :p
Opinions?
:p
EDIT:
It looks like power didnt stop to go up at at the end of test, maybe i could get some more hp out ? hehe
jonesy118
388
Cheshire
really liking the front end Greesha, may be tempted by the honeycombe grille myself. How much was it, and did you get it from a local dealers or from Sere motors?
greesha
Jan 6, 2009
496
Slough
Jonesy i asked local dealers for a price and then i've asked David from sere motors for a price and it was quite a huge difference. Seremotors much cheaper. Altogether with delivery and cupra badge it was around 55 - 60 quid ? not sure now.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'd say you should have more torque with the FMIC not less?
Even unmapped mine was a lot more torquey.
Figures don't look to bad tho? 225 is very good for a stage 1?
greesha
Jan 6, 2009
496
Slough
Torque is way more important than BHP :<. And after all those mods i have lost torque which is quite sad.
irmscher2007
64
Cheshire
Hello.
I read a post that you have bought some OzTitans. Are they fitted yet?
Would love to see some pictures if so.
I would like a set of these and refurb them to anachrite.
irmscher2007
64
Cheshire
Brilliant, thanks for that.
I'll keep an eye out for your pics.
Did you buy brand new or second hand?
There are some 17s on ebay 2nd hand but dont have centre caps. Think these cost about £80 for the caps.
greesha
Jan 6, 2009
496
Slough
i bought mine off ebay. Set of 4 with centre caps for 65 pounds :D
They will need refurb thought. Delivered yesterday.
