Face lift Cupra with Needle sweep.
Green1o
Bathgate, M8 J4, Scotland! Will meet you somewhere in Glasgow of your still coming up?
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Hi have done:
Staging Needle Sweep
Fog Light Assistance (Turned off)
Rest of the World Large MDF Speedo
Seat Belt Warning (Turned off)
Daytime Lights (DRL) - Was On, Currently Off
I am sure there are a few more, will let you know as I think of them!!
I am here: http://maps.google.com/maps?ll=54.791508,-1.490755
we've had needle sweep and alarm chirp enabled (cheers Greg!) not got DRL's so not capable but like the large MFD speedo idea.... care to elaborate, does it change it from the current small kph display to large mph?
May 7, 2011
1,044
North East, UK
Good call!! Spot on, should have come down to the yorkshire meet LeonES!! Down here now!!
The large MFD Spedo:
I am here: http://maps.google.com/maps?ll=53.708166,-1.341155
Green1o
Yeah I will let you know, don't actually have a date yet, but it will probably be either end of the month or march!! But sure I can do it for you!!
Hey Jmerrie, just wondering if your still coming up?
Green1o
There was one in Aberdeen but don't know of any locally! No rush for it anyway, just let's know.
GrahamFR
Now AMG Powered
Dec 10, 2008
4,239
Barnsley or Burton
This is probably a stupid question, but what is VAG-COM and where can I get access to it??
VCDS is a piece of software and it should come with a cable that plugs into your obd port which is located to the right of your steering wheel behind a panel that clips out. It lets you basically talk to car, read its errors and change things like a chirp noise when you lock the car and hazard lights when you brake hard or turn your seat belt alarm off etc etc. Real software can cost a bit, can be found at Ross tech, but there are older software you can get from eBay for like £20 - 50!
Failing this... If I give one of the guys in my local SEAT service dept the instructions on here, could they do it?:shrug:
depending where you are in Manchester, im sure awesome gti could do this for a small fee, there on here and based in Irlam
