Face lift Cupra with Needle sweep.
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Hello Tarek,
I don't know of any other garages except the Seat one which has VCDS.
It's not just the MY that's applicable here but the cluster part number, as yours is a petrol your cluster will have totally different firmware from mines.
Until I hear from someone with the same P/N cluster from a MY12 2.0 TDi 140 that has succesfully enabled staging I'm just going to accept it can't be done.
Paul
How do I get the cluster P/N?
Is it stamped somewhere or does CVDS come up with it?
elpaulio
Nath,
Just go into 17 - Instruments on VCDS and its there.
You can see mine in the last page as 1P0 920 950 N in the screenshot ive put up
Paul
Nath.
Jan 1, 2006
8,619
16
Just checked, plugged VCDS in before I left for work this morning and my P/N is the same as yours apart from the last digit. 1P0 920 950 K.
elpaulio
Hmm... having dealt with VAG for a number of yers, generally the last Digit indicates the revision (latter the letter newer the revision) so looks like Seat may have taken it out :(
Paul
KWEV
97
Just tried enabling sweep on my MY12 super-copa TDI and get the same
error label as paul, didn't look at the cluster number, but will re-check & report
back. I thought it might be because i only have the 912 cable, but i too have a distinct feeling it cannot be done on the later clusters.
just hoping mine is because of the cable:shrug:
KWEV
97
Well having checked today , my module is also the 1P0 920 950 N
version, so looks like anyone with this cluster part number cannot activate
needle sweep:cry:
If anyone knows any different or manages to do this please let me know:)
S3 AKR
livin' the dream!!!
Jun 30, 2004
1,453
Colchester, Essex
My VCDS won't read my November 62 plate Supercopa at all (version 812) so I guess it's time to think about buying the latest and greatest. I am expecting that the 2012 cars won't work with the sweep function as they seem to have newer modules etc...... Shame as my mates 60 plate TTS does it and it looks great!
Dec 28, 2011
1,250
Cairo, Egypt
I've been wondering if the dashboard lights turn off when the needle sweep is activated and then turns on again once it's done for anyone who was able to activate it? That's how it has been for me ever since I activated it.
Al
7,326
9
Chaps,
Digging up an old thread. We have a 2008 MK2 Leon with instrument controller 1P0 920 925 C and we would like to set up the staging on it.
We have read all the way through here and other threads and from what we can see, it may not be possible with VCDS ( I am running latest version via a genuine cable). What we would like to know is exactly how it could be possible - assuming the posts about dealers being able to do it are correct. Are they changing the control module to do this or are they able to adjust the Software Coding ID (available is 0 - 8388607) and is currently set to 0006401. The car has no MFD.
Cheers,
Al
Dec 19, 2009
84
Stoke
Carista app and you can do all of these mods by just pressing a button I think you need an obd2 bluetooth or wifi depending on if you have an iphone or not
