DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
New pipe turned up today and its all fitted...But i have a boost leak somewere as its only boosting to 10psi on WOT
and i can here a whinning sound wen boost starts to build so ive defo got a leak somewere...
before doing this boost would Build from 2.9krpm and full boost by 4.1krpm...
Now even with a leak somewhere im getting boost from 2.2krpm+...
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Looking good mate, like the blue ducting you got on there ;)
Did you manage to do the jubilee up on the turbo in the end then?
Id check the metal pipe coming off the joiner from the TB first as when i looked other night looked abit suspect and i know that one of them are them crap pipes that you wanna replace
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Looks very nice.
But 2 questions; why did you opt to run the DV from throttle, and where is your n75 valve if you even still have it because I can't see it
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Curzon:Nah i done it up the best i could on the turbo but sure it isnt tigther enough...
The rest of the couplers are spot on...Defo here it whinning like the charge pipe hose has popped off or even loose...Could'nt have a prober look as its snowing :D
Reuvers:I Done the Dv of the throttle bodie as my charge pipe doesnt have a pipe coming of it to run the dv..So done a Cold Side recolation kit which i made my self...fairly simple
The N75 is cable tied down near the engine as its electronically plugged in but isnt plumbed in as use a MBC which runs of the silicone Pipe coming of the Charge pipe near the turbo.
you can Just about see the hose from the mbc goin to the silcone pipe of my turbo...I used a Self sealing bung 5mm from merlin motorsport...
So basically i did everything my self didnt have to weld anything ect..
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
When the weather gets better mate will come down with that bendy extension thing for you so you can tighten it up a bit more if you want?
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Danny could you get me a pic of this route in the light? I have the LCR chargepipe, but thinking of making it totally MIG welded custom job, but not sure if I'll weld 2 ports in the chargepipe for N75 and DV, or run it from elsewhere as you have done.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Not a problem Reuvers,Might have to be taken on a weekend tho as when i get in from work its dark...
Are you in a rush for it?:D
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
This is the old Ths Fmic and Silicone pipework with Ngk bk7re plugs fitted
Code:
	Group A:	'002				Group B:	'020
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME
MARKER	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
	0.01	2320	9	1.23	4.19	0.38	0	0	0	0
	0.89	2440	57.9	6.97	28.75	1.29	7.5	4.5	6.8	6
	1.69	2600	63.2	6.56	32.61	2.09	6	3	4.5	4.5
	2.59	2800	69.2	7.38	38.5	3.01	6	3	3.8	4.5
	3.5	3040	85	9.43	53.06	4	6	3	1.5	4.5
	4.49	3400	114.3	14.35	81.06	4.89	6	3	0.8	3
	5.29	3800	136.8	18.45	103.94	5.81	5.3	6	3	5.3
	6.21	4280	157.1	21.73	130.83	6.61	5.3	6	6	7.5
	7.01	4680	157.1	22.55	140.28	7.39	7.5	6	6	9.8
	7.79	5040	151.1	22.14	145.03	8.19	7.5	10.5	9	9.8
	8.6	5320	145.9	21.73	150.11	8.99	7.5	10.5	9	9.8
	9.39	5640	138.3	20.5	150.72	9.79	7.5	10.5	9	12
	10.19	5840	136.1	20.09	152.22	10.59	7.5	10.5	9	12
	10.99	6080	132.3	19.68	153.92	11.39	7.5	10.5	9	12
This is a run with the new Fmic And Pipework but with Ngk bk7re plugs fitted
Code:
,Group A:,'020,,,,Group B:,'002,,,,Group C:, Not Running
,,Idle Stabilization,Idle Stabilization,Idle Stabilization,Idle Stabilization,,RPM,Load,Inj. On Time,Mass Flow,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, CF, CF, CF, CF,STAMP, /min,%, ms, g/s,STAMP,,,,
,0.40,1.5,0.0,3.0,3.0,0.01,3280,49.6,8.20,37.11,,,,,
,1.20,0.0,0.0,2.3,2.3,0.80,3440,90.2,10.25,67.39,,,,,
,2.10,3.0,0.0,1.5,1.5,1.60,3800,146.6,19.68,115.03,,,,,
,2.90,5.3,3.0,3.8,4.5,2.50,4360,163.2,22.55,134.28,,,,,
,3.70,5.3,6.0,3.8,4.5,3.30,4760,154.9,21.73,140.64,,,,,
,4.50,5.3,6.0,3.8,4.5,4.10,5160,149.6,21.32,145.64,,,,,
,5.29,5.3,6.0,3.8,4.5,4.90,5520,142.1,20.09,147.89,,,,,
,6.09,5.3,6.0,3.8,4.5,5.69,5760,136.8,19.68,150.89,,,,,
,6.89,4.5,6.0,3.8,3.8,6.49,6040,132.3,19.27,152.33,,,,,
,7.69,4.5,5.3,6.0,3.8,7.29,6280,127.8,18.45,152.58,,,,,
,8.51,4.5,5.3,6.0,6.8,8.11,6480,123.3,18.04,153.67,,,,,
,9.39,4.5,5.3,6.0,6.8,8.91,6720,121.1,17.63,153.39,,,,,
,10.22,4.5,5.3,6.0,6.8,9.82,6880,115.8,16.81,151.69,,,,,
This is a Run with the new FMIC and Pipwork But with my Ik22 plugs Fitted:
Code:
,0.00,0.0,0.0,0.0,0.0,0.40,3240,59.4,7.79,42.92,,,,,
,0.89,2.3,3.8,6.8,5.3,1.29,3480,112.8,14.76,86.83,,,,,
,1.69,1.5,3.0,6.8,3.8,2.09,3920,163.2,22.96,126.72,,,,,
,2.49,0.8,2.3,6.0,3.8,2.89,4400,163.2,23.37,135.14,,,,,
,3.29,3.8,5.3,6.0,3.0,3.69,4840,155.6,22.55,142.39,,,,,
,4.09,3.8,5.3,4.5,3.0,4.59,5240,149.6,22.14,148.89,,,,,
,4.99,3.8,5.3,3.8,6.0,5.50,5600,140.6,20.91,150.11,,,,,
,5.90,3.8,5.3,3.8,6.0,6.30,5880,135.3,20.09,151.69,,,,,
,6.70,3.8,5.3,3.8,6.0,7.10,6160,130.8,19.68,154.19,,,,,
,7.50,3.0,4.5,3.8,6.0,7.90,6360,126.3,18.86,153.39,,,,,
,8.30,3.0,4.5,3.8,6.8,8.70,6560,122.6,18.04,154.19,,,,,
,9.12,3.0,6.8,3.0,6.8,9.50,6760,118.8,17.63,153.00,,,,,
,9.92,3.0,6.8,3.0,6.8,10.41,6960,114.3,16.81,153.14,,,,,
wild willy
2,323
Wales
Yeah i was Just going to do that But my Laptop was deads which i was uber pissed off about.....
How do i set the logs out like the 1st log that i done the the ths cooler....
il go do 118 and 115 now
The reason the logs end squashed up is because you have respecified where you want the log file saved and must have left the csv file extension of the end.
I would simply accept where ever vagcom tells you it is going to leave the file and not change its name or location and all will be well.
edit. drive carefully its icy out there.
P-torque.co.uk
1,075
Wolverhampton
www.p-torque.co.uk
I can't believe you are still running the car whilst pulling that amount of timing. Over 10 = Very dangerous for the engine.
I'd avoid keep loading it up under boost
Send me the CSV log files so I can see them more clearly :)
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
,Group A:,'118,,,,Group B:,'115,,,,Group C:, Not Running
,,RPM,Temperature,Load,Absolute Pres.,,RPM,Load,Absolute Pres.,Absolute Pres.,,,,,
MARKER,STAMP, /min,°C,%, mbar,STAMP, /min,%, mbar, mbar,STAMP,,,,
,1.04,2960,15.0,0.0,1030.0,0.54,2920,31.6,980.0,1010.0,,,,,
,1.84,3160,15.0,0.0,1390.0,1.46,3040,66.2,980.0,1210.0,,,,,
,2.64,3360,14.0,1.2,1620.0,2.24,3240,73.7,980.0,1470.0,,,,,
,3.46,3640,14.0,1.2,1960.0,3.06,3520,92.5,1110.0,1820.0,,,,,
,4.45,4200,15.0,1.2,2500.0,3.95,3920,142.9,2010.0,2230.0,,,,,
,5.25,4600,15.0,1.2,2480.0,4.85,4400,160.9,1960.0,2530.0,,,,,
,6.05,5000,16.0,1.2,2410.0,5.65,4840,151.1,2300.0,2440.0,,,,,
,6.94,5400,18.0,1.2,2330.0,6.45,5200,146.6,2260.0,2380.0,,,,,
,7.85,5760,18.0,1.2,2250.0,7.45,5600,138.3,2200.0,2280.0,,,,,
,8.65,6040,20.0,1.2,2180.0,8.25,5880,133.8,2160.0,2220.0,,,,,
,9.44,6280,21.0,65.9,2080.0,9.04,6160,131.6,2170.0,2110.0,,,,,
,10.27,6480,23.0,91.4,2080.0,9.87,6360,125.6,2170.0,2080.0,,,,,
,11.15,6680,24.0,93.3,2060.0,10.67,6560,123.3,2160.0,2070.0,,,,,
,12.06,6880,24.0,92.2,2040.0,11.55,6800,118.8,2170.0,2050.0,,,,,
Code:
,Group A:,'032,,,,Group B:,'031,,,,Group C:, Not Running
,,Lambda,Lambda,Bin. Bits,Bin. Bits,,Voltage,Voltage,Bin. Bits,Bin. Bits,,,,,
MARKER,STAMP,%,%,,,STAMP, V, V,,,STAMP,,,,
,0.38,0.0,0.0,        ,        ,0.01,0.435,0.435,        ,        ,,,,,
,1.18,0.0,0.0,        ,        ,0.78,0.435,0.435,        ,        ,,,,,
,1.98,0.0,0.0,        ,        ,1.58,0.435,0.435,        ,        ,,,,,
,2.78,0.0,0.0,        ,        ,2.38,0.435,0.435,        ,        ,,,,,
,3.58,0.0,0.0,        ,        ,3.18,0.435,0.435,        ,        ,,,,,
,4.38,0.0,0.0,        ,        ,3.98,0.435,0.430,        ,        ,,,,,
,5.18,0.0,0.0,        ,        ,4.78,0.435,0.435,        ,        ,,,,,
,5.98,0.0,0.0,        ,        ,5.58,0.435,0.435,        ,        ,,,,,
,6.89,0.0,0.0,        ,        ,6.38,0.435,0.435,        ,        ,,,,,
,7.79,0.0,0.0,        ,        ,7.29,0.435,0.435,        ,        ,,,,,
,8.59,0.0,0.0,        ,        ,8.19,0.435,0.435,        ,        ,,,,,
,9.39,0.0,0.0,        ,        ,8.99,0.435,0.435,        ,        ,,,,,
,10.29,0.0,0.0,        ,        ,9.79,0.435,0.435,        ,        ,,,,,
,11.09,0.0,0.0,        ,        ,10.69,0.435,0.435,        ,        ,,,,,
,11.98,0.0,0.0,        ,        ,11.58,0.435,0.435,        ,        ,,,,,
,12.89,0.0,0.0,        ,        ,12.49,0.435,0.435,        ,        ,,,,,
,13.69,0.0,0.0,        ,        ,13.29,0.435,0.435,        ,        ,,,,,
,14.49,0.0,0.0,        ,        ,14.09,0.435,0.435,        ,        ,,,,,
,15.28,0.0,0.0,        ,        ,14.89,0.435,0.435,        ,        ,,,,,
,16.08,0.0,0.0,        ,        ,15.68,0.435,0.430,        ,        ,,,,,
,16.88,0.0,0.0,        ,        ,16.48,0.435,0.435,        ,        ,,,,,
,17.68,0.0,0.0,        ,        ,17.28,0.435,0.435,        ,        ,,,,,
,18.48,0.0,0.0,        ,        ,18.08,0.435,0.435,        ,        ,,,,,
,19.28,0.0,0.0,        ,        ,18.88,0.435,0.435,        ,        ,,,,,
,20.08,0.0,0.0,        ,        ,19.68,0.435,0.435,        ,        ,,,,,
,20.88,0.0,0.0,        ,        ,20.48,0.435,0.435,        ,        ,,,,,
,21.68,0.0,0.0,        ,        ,21.28,0.435,0.435,        ,        ,,,,,
,22.48,0.0,0.0,        ,        ,22.08,0.435,0.430,        ,        ,,,,,
,23.28,0.0,0.0,        ,        ,22.88,0.430,0.435,        ,        ,,,,,
,24.19,0.0,0.0,        ,        ,23.68,0.435,0.435,        ,        ,,,,,
,24.99,0.0,0.0,        ,        ,24.59,0.435,0.435,        ,        ,,,,,
,25.79,0.0,0.0,        ,        ,25.39,0.435,0.435,        ,        ,,,,,
il P-torque il send them you now...Il go and knock the timing back A tad -0.75 or what ever it is..
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Here so we can read them properly, doesent look good off logs though maf reading is really low and those cf's are shocking still.
Code:
	Group A:	'020				Group B:	'002
		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Inj. On Time	Mass Flow
	TIME					TIME
MARKER	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 ms	 g/s
	0	0	0	0	0	0.4	3240	59.4	7.79	42.92
	0.89	2.3	3.8	6.8	5.3	1.29	3480	112.8	14.76	86.83
	1.69	1.5	3	6.8	3.8	2.09	3920	163.2	22.96	126.72
	2.49	0.8	2.3	6	3.8	2.89	4400	163.2	23.37	135.14
	3.29	3.8	5.3	6	3	3.69	4840	155.6	22.55	142.39
	4.09	3.8	5.3	4.5	3	4.59	5240	149.6	22.14	148.89
	4.99	3.8	5.3	3.8	6	5.5	5600	140.6	20.91	150.11
	5.9	3.8	5.3	3.8	6	6.3	5880	135.3	20.09	151.69
	6.7	3.8	5.3	3.8	6	7.1	6160	130.8	19.68	154.19
	7.5	3	4.5	3.8	6	7.9	6360	126.3	18.86	153.39
	8.3	3	4.5	3.8	6.8	8.7	6560	122.6	18.04	154.19
	9.12	3	6.8	3	6.8	9.5	6760	118.8	17.63	153
	9.92	3	6.8	3	6.8	10.41	6960	114.3	16.81	153.14
Code:
	TIME					TIME
	0.4	1.5	0	3	3	0.01	3280	49.6	8.2	37.11
	1.2	0	0	2.3	2.3	0.8	3440	90.2	10.25	67.39
	2.1	3	0	1.5	1.5	1.6	3800	146.6	19.68	115.03
	2.9	5.3	3	3.8	4.5	2.5	4360	163.2	22.55	134.28
	3.7	5.3	6	3.8	4.5	3.3	4760	154.9	21.73	140.64
	4.5	5.3	6	3.8	4.5	4.1	5160	149.6	21.32	145.64
	5.29	5.3	6	3.8	4.5	4.9	5520	142.1	20.09	147.89
	6.09	5.3	6	3.8	4.5	5.69	5760	136.8	19.68	150.89
	6.89	4.5	6	3.8	3.8	6.49	6040	132.3	19.27	152.33
	7.69	4.5	5.3	6	3.8	7.29	6280	127.8	18.45	152.58
	8.51	4.5	5.3	6	6.8	8.11	6480	123.3	18.04	153.67
	9.39	4.5	5.3	6	6.8	8.91	6720	121.1	17.63	153.39
	10.22	4.5	5.3	6	6.8	9.82	6880	115.8	16.81	151.69
Saturday	7	February	2009	14:38:28
Code:
	Group A:	'118				Group B:	'115				Group C:
		RPM	Temperature	Load	Absolute Pres.		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	°C	%	 mbar	STAMP	 /min	%	 mbar	 mbar	STAMP
	1.04	2960	15	0	1030	0.54	2920	31.6	980	1010
	1.84	3160	15	0	1390	1.46	3040	66.2	980	1210
	2.64	3360	14	1.2	1620	2.24	3240	73.7	980	1470
	3.46	3640	14	1.2	1960	3.06	3520	92.5	1110	1820
	4.45	4200	15	1.2	2500	3.95	3920	142.9	2010	2230
	5.25	4600	15	1.2	2480	4.85	4400	160.9	1960	2530
	6.05	5000	16	1.2	2410	5.65	4840	151.1	2300	2440
	6.94	5400	18	1.2	2330	6.45	5200	146.6	2260	2380
	7.85	5760	18	1.2	2250	7.45	5600	138.3	2200	2280
	8.65	6040	20	1.2	2180	8.25	5880	133.8	2160	2220
	9.44	6280	21	65.9	2080	9.04	6160	131.6	2170	2110
	10.27	6480	23	91.4	2080	9.87	6360	125.6	2170	2080
	11.15	6680	24	93.3	2060	10.67	6560	123.3	2160	2070
	12.06	6880	24	92.2	2040	11.55	6800	118.8	2170	2050
dont know why you've done these but will post them up for you
Code:
		Group A:	'032				Group B:	'031
		Lambda	Lambda	Bin. Bits	Bin. Bits		Voltage	Voltage
	TIME					TIME
MARKER	STAMP	%	%			STAMP	 V	 V
	0.38	0	0	        	        	0.01	0.435	0.435
	1.18	0	0	        	        	0.78	0.435	0.435
	1.98	0	0	        	        	1.58	0.435	0.435
	2.78	0	0	        	        	2.38	0.435	0.435
	3.58	0	0	        	        	3.18	0.435	0.435
	4.38	0	0	        	        	3.98	0.435	0.43
	5.18	0	0	        	        	4.78	0.435	0.435
	5.98	0	0	        	        	5.58	0.435	0.435
	6.89	0	0	        	        	6.38	0.435	0.435
	7.79	0	0	        	        	7.29	0.435	0.435
	8.59	0	0	        	        	8.19	0.435	0.435
	9.39	0	0	        	        	8.99	0.435	0.435
	10.29	0	0	        	        	9.79	0.435	0.435
	11.09	0	0	        	        	10.69	0.435	0.435
	11.98	0	0	        	        	11.58	0.435	0.435
	12.89	0	0	        	        	12.49	0.435	0.435
	13.69	0	0	        	        	13.29	0.435	0.435
	14.49	0	0	        	        	14.09	0.435	0.435
	15.28	0	0	        	        	14.89	0.435	0.435
	16.08	0	0	        	        	15.68	0.435	0.43
	16.88	0	0	        	        	16.48	0.435	0.435
	17.68	0	0	        	        	17.28	0.435	0.435
	18.48	0	0	        	        	18.08	0.435	0.435
	19.28	0	0	        	        	18.88	0.435	0.435
	20.08	0	0	        	        	19.68	0.435	0.435
	20.88	0	0	        	        	20.48	0.435	0.435
	21.68	0	0	        	        	21.28	0.435	0.435
	22.48	0	0	        	        	22.08	0.435	0.43
	23.28	0	0	        	        	22.88	0.43	0.435
	24.19	0	0	        	        	23.68	0.435	0.435
	24.99	0	0	        	        	24.59	0.435	0.435
	25.79	0	0	        	        	25.39	0.435	0.435
