DaNnY_LaD's IHI'd Cupra ( End Of a Eara 08/11/2009)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Hi Bill
Ive Been told of a numberous people that Unisettings is alot easyer than Lemmiwinks So ive downloaded the Unisettings of Vwvortex and its all in stalled...
But for making it leaner on Full w.o.t what does it come under section wise as my afr is 10.8/11.0.Is it the section fueling on increasing Load and i slowly bring it down from 100% and log each time....?so for example down to 99.2% then re log it and so on....
And also what part is it to make it slighlty leaner on Idle...As im seeing 13.8/14.2 so would need to make it a tad leaner...not much mind...
to lean out everywhere Ch10 reduce the percentage
to lean out under boost (load) reduce Ch02
If adjusting out overall fueling on Ch10, check block 001 for lambda live trim... it shoudl sit hovering above and below zero when spot on as a guide.. it does'nt have to be zero, but is an indication of whats being pulled or added on idle according to the lambda.
if this number is around the zero, then you are seeing a difference between the wideband lambda & the cars narrowband which is whats trying to achieve the lambda of 1 on idle anyhow.
adjust a couple of percent and relog... little and often
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
take note of block 001 tho... if its close to zero and your wideband is reading different the ecu will still try and control to lambda off its own probe.. and you may chase your tail when its just discrepency between the two lambdas.
under boost fueling is where you can only really use your wideband to confirm the adjustments are ok
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
So in your person opioin should i just leave the richness of the Idle as its flickers around 13.7 & 14.5 doesnt go any higher or lower than that...Kinda fluctuates
I understand it more now massive learning curve for me which i am enjoyin tbh...When you mapped pj IHI on CC3 and it was a tad too rich did you do the same steps as what im doing...And can you remember how far Down you went %..Not that im going to match it just curous thats all...
Alex said to me when i receive my SPS3 And up the timing it will add more fuel so i have to lean it out to near 11.5 he's said for the IHI...
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
its adding 17% more fuel on idle?
but is also too rich under boost
you are going to have fun trying to unisettings this into a decent tune
SPS3 has no fuel adjustment on me7 ecu, ign and boost only - why does alex think this will adjust fueling? its looking wrong both ends of the scale from what I read you say
I would adjust main fuel up so block 001 is closer to zero, and recheck fueling under boost after. (CAREFULLY)
you have your wideband to confirm the fueling tweaks
gently does it
REVO stage 3 is as far as I know it an early 8L0 file flashed into an ibiza ecu... not desperately clever or suited to an ihi
all imho
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
gently does it
all imho
So I should adjust channel 10 via unisettings and log 001 each time till it settles at or near 0? also use the - not the + ...
Just sorting the block out now for u..
Code:
Monday,31,August,2009,15:32:58
6K0 906 032 AA ,,1.8L 20VT EU3    01 0002,
,Group A:,'001,,,,Group B:, Not Running,,,,Group C:, Not Running
,,RPM,Temperature,Lambda,Bin. Bits,,,,,,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min,°C,%,,STAMP,,,,,STAMP,,,,
,0.01,840,85.0,0.0,00110111,,,,,,,,,,
,0.38,840,84.0,0.0,00110111,,,,,,,,,,
,0.78,840,85.0,0.0,00110111,,,,,,,,,,
,1.18,840,85.0,0.0,00110111,,,,,,,,,,
,1.58,840,85.0,0.0,00110111,,,,,,,,,,
,1.98,840,85.0,0.0,00110111,,,,,,,,,,
,2.38,840,84.0,0.0,00110111,,,,,,,,,,
,2.78,840,85.0,0.0,00111111,,,,,,,,,,
,3.18,840,84.0,0.8,00111111,,,,,,,,,,
,3.58,840,84.0,1.6,00111111,,,,,,,,,,
,3.98,840,85.0,2.3,00111111,,,,,,,,,,
,4.38,840,84.0,3.9,00111111,,,,,,,,,,
,4.78,840,84.0,4.7,00111111,,,,,,,,,,
,5.18,840,85.0,5.5,00111111,,,,,,,,,,
,5.58,840,85.0,6.3,00111111,,,,,,,,,,
,5.98,840,85.0,7.0,00111111,,,,,,,,,,
,6.38,840,85.0,7.8,00111111,,,,,,,,,,
,6.78,840,84.0,8.6,00111111,,,,,,,,,,
,7.18,840,84.0,10.2,00111111,,,,,,,,,,
,7.58,840,85.0,10.9,00111111,,,,,,,,,,
,7.98,840,84.0,11.7,00111111,,,,,,,,,,
,8.38,840,85.0,12.5,00111111,,,,,,,,,,
,8.78,840,85.0,13.3,00111111,,,,,,,,,,
,9.18,840,84.0,14.1,00111111,,,,,,,,,,
,9.67,840,84.0,14.8,00111111,,,,,,,,,,
,10.28,840,85.0,14.1,00111111,,,,,,,,,,
,10.68,840,85.0,13.3,00111111,,,,,,,,,,
,11.18,840,84.0,12.5,00111111,,,,,,,,,,
,11.58,840,85.0,10.9,00111111,,,,,,,,,,
,11.98,840,85.0,12.5,00111111,,,,,,,,,,
,12.47,840,84.0,14.1,00111111,,,,,,,,,,
,12.87,840,84.0,14.8,00111111,,,,,,,,,,
,13.39,840,85.0,15.6,00111111,,,,,,,,,,
,13.88,840,85.0,17.2,00111111,,,,,,,,,,
,14.28,840,85.0,14.1,00111111,,,,,,,,,,
,14.68,840,85.0,13.3,00111111,,,,,,,,,,
,15.18,840,85.0,12.5,00111111,,,,,,,,,,
,15.67,840,85.0,14.1,00111111,,,,,,,,,,
,16.07,840,84.0,14.8,00111111,,,,,,,,,,
,16.47,840,85.0,15.6,00111111,,,,,,,,,,
,16.87,840,85.0,16.4,00111111,,,,,,,,,,
,17.27,840,85.0,18.0,00111111,,,,,,,,,,
,17.67,840,85.0,16.4,00111111,,,,,,,,,,
,18.07,840,84.0,15.6,00111111,,,,,,,,,,
,18.47,840,85.0,14.8,00111111,,,,,,,,,,
,18.98,840,85.0,13.3,00111111,,,,,,,,,,
,19.38,840,85.0,14.8,00111111,,,,,,,,,,
,19.78,840,84.0,16.4,00111111,,,,,,,,,,
,20.18,840,85.0,17.2,00111111,,,,,,,,,,
,20.58,840,85.0,18.0,00111111,,,,,,,,,,
,20.98,840,85.0,18.8,00111111,,,,,,,,,,
,21.38,840,85.0,19.5,00111111,,,,,,,,,,
,21.78,840,85.0,18.0,00111111,,,,,,,,,,
,22.18,840,85.0,17.2,00111111,,,,,,,,,,
,22.58,800,85.0,16.4,00111111,,,,,,,,,,
,22.98,840,85.0,15.6,00111111,,,,,,,,,,
,23.38,840,85.0,16.4,00111111,,,,,,,,,,
,23.78,840,85.0,17.2,00111111,,,,,,,,,,
,24.18,840,85.0,18.0,00111111,,,,,,,,,,
,24.58,840,85.0,18.8,00111111,,,,,,,,,,
,24.98,840,85.0,19.5,00111111,,,,,,,,,,
,25.38,840,86.0,18.0,00111111,,,,,,,,,,
,25.78,840,85.0,17.2,00111111,,,,,,,,,,
,26.18,840,85.0,16.4,00111111,,,,,,,,,,
,26.58,840,85.0,15.6,00111111,,,,,,,,,,
,26.98,840,85.0,14.8,00111111,,,,,,,,,,
,27.38,840,86.0,15.6,00111111,,,,,,,,,,
,27.78,840,86.0,17.2,00111111,,,,,,,,,,
,28.18,840,86.0,18.0,00111111,,,,,,,,,,
,28.58,840,86.0,18.8,00111111,,,,,,,,,,
,28.98,840,86.0,19.5,00111111,,,,,,,,,,
,29.48,840,86.0,18.0,00111111,,,,,,,,,,
,29.88,840,86.0,17.2,00111111,,,,,,,,,,
,30.28,840,86.0,16.4,00111111,,,,,,,,,,
,30.77,840,85.0,15.6,00111111,,,,,,,,,,
,31.27,840,86.0,14.1,00111111,,,,,,,,,,
,31.67,840,86.0,17.2,00111111,,,,,,,,,,
,32.28,840,304.34,231 001 200,0.050,,,,,,,,,,
,41.57,840,86.0,15.6,00111111,,,,,,,,,,
,42.07,840,86.0,14.8,00111111,,,,,,,,,,
,42.47,840,87.0,16.4,00111111,,,,,,,,,,
,42.96,840,86.0,17.2,00111111,,,,,,,,,,
,43.48,840,86.0,18.0,00111111,,,,,,,,,,
,43.87,840,87.0,19.5,00111111,,,,,,,,,,
,44.27,840,86.0,20.3,00111111,,,,,,,,,,
,44.67,840,87.0,17.2,00111111,,,,,,,,,,
,45.07,840,87.0,16.4,00111111,,,,,,,,,,
,45.57,840,87.0,15.6,00111111,,,,,,,,,,
,46.07,840,87.0,14.8,00111111,,,,,,,,,,
,46.56,840,87.0,16.4,00111111,,,,,,,,,,
,46.96,840,87.0,17.2,00111111,,,,,,,,,,
,47.36,840,87.0,18.0,00111111,,,,,,,,,,
,47.76,840,87.0,19.5,00111111,,,,,,,,,,
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Danny, add (code) before and add (/code) after your logs but replace () with []
Just copy and past from the excel file and add the above..
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Ive been out side and i took It to -8% on the primary fuel trim via unisettings...But on the 001 i was seeing 24%....
the - i went the higher the number % on vagcom so i spoke to alex he said he wasnt sure which was lean/rich on vagcom so i did it the other way + and added 4% and on 001 its stayin between -3.3 0 2.3 either end of the scale...
Instead of it -8% and 001 block 24%....Its now +4% and 001 block -3.3 / 2.3
Wilko
Badge snob
so the ecu's having to chuck in more fuel than the maf thinks it should on idle, then there is likely unmetered air entering the engine (vac leak) and underboost it needs to take fuel out at the maf is metering more air than the engine is seeing (boost leak)
I'd be lookng for leaks between turbo and intake mani.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Block 001 with the Primary enrich fuel set to 0%.
I have no idea why i was getting them number isn my earlier log...
Code:
,0.57,840,92.0,-0.8,00111111,,,,,,,,,,
,0.97,840,92.0,-1.6,00111111,,,,,,,,,,
,1.46,840,92.0,-2.3,00111111,,,,,,,,,,
,1.86,840,92.0,-1.6,00111111,,,,,,,,,,
,2.38,840,92.0,0.0,00111111,,,,,,,,,,
,2.78,840,92.0,0.8,00111111,,,,,,,,,,
,3.27,840,92.0,1.6,00111111,,,,,,,,,,
,3.77,840,93.0,0.8,00111111,,,,,,,,,,
,4.17,840,92.0,-0.8,00111111,,,,,,,,,,
,4.66,840,93.0,-1.6,00111111,,,,,,,,,,
,5.17,840,92.0,-2.3,00111111,,,,,,,,,,
,5.57,840,93.0,-1.6,00111111,,,,,,,,,,
,5.97,840,92.0,-0.8,00111111,,,,,,,,,,
,6.37,840,92.0,0.0,00111111,,,,,,,,,,
,6.87,840,92.0,1.6,00111111,,,,,,,,,,
,7.37,840,92.0,2.3,00111111,,,,,,,,,,
,7.77,840,93.0,0.0,00111111,,,,,,,,,,
,8.26,840,93.0,-1.6,00111111,,,,,,,,,,
,8.66,840,93.0,-2.3,00111111,,,,,,,,,,
,9.06,840,92.0,-3.1,00111111,,,,,,,,,,
,9.57,840,93.0,-1.6,00111111,,,,,,,,,,
,9.97,840,93.0,-0.8,00111111,,,,,,,,,,
,10.37,840,93.0,0.8,00111111,,,,,,,,,,
,10.77,840,93.0,1.6,00111111,,,,,,,,,,
,11.17,840,93.0,2.3,00111111,,,,,,,,,,
,11.57,840,92.0,0.8,00111111,,,,,,,,,,
,11.97,840,93.0,0.0,00111111,,,,,,,,,,
,12.37,840,92.0,-0.8,00111111,,,,,,,,,,
,12.76,840,93.0,-1.6,00111111,,,,,,,,,,
,13.17,840,93.0,-2.3,00111111,,,,,,,,,,
,13.56,840,92.0,-3.1,00111111,,,,,,,,,,
,13.96,840,92.0,-0.8,00111111,,,,,,,,,,
,14.37,840,92.0,0.0,00111111,,,,,,,,,,
,14.87,840,93.0,0.8,00111111,,,,,,,,,,
,15.27,840,92.0,1.6,00111111,,,,,,,,,,
,15.67,840,93.0,3.1,00111111,,,,,,,,,,
,16.07,840,92.0,0.0,00111111,,,,,,,,,,
,16.47,840,92.0,-0.8,00111111,,,,,,,,,,
,16.87,840,92.0,-1.6,00111111,,,,,,,,,,
,17.27,840,92.0,-2.3,00111111,,,,,,,,,,
,17.76,840,92.0,-0.8,00111111,,,,,,,,,,
,18.26,840,92.0,0.0,00111111,,,,,,,,,,
,18.66,840,93.0,0.8,00111111,,,,,,,,,,
,19.06,840,93.0,1.6,00111111,,,,,,,,,,
,19.46,840,93.0,0.0,00111111,,,,,,,,,,
,19.86,840,92.0,-0.8,00111111,,,,,,,,,,
,20.26,840,93.0,-1.6,00111111,,,,,,,,,,
,20.66,840,92.0,-2.3,00111111,,,,,,,,,,
,21.06,840,92.0,-3.1,00111111,,,,,,,,,,
,21.46,840,93.0,-0.8,00111111,,,,,,,,,,
,21.86,840,93.0,0.8,00111111,,,,,,,,,,
,22.35,840,92.0,1.6,00111111,,,,,,,,,,
,22.77,840,93.0,-0.8,00111111,,,,,,,,,,
,23.15,840,92.0,-1.6,00111111,,,,,,,,,,
,23.55,840,93.0,-2.3,00111111,,,,,,,,,,
,23.95,840,92.0,-0.8,00111111,,,,,,,,,,
,24.35,840,93.0,0.0,00111111,,,,,,,,,,
,24.75,840,92.0,0.8,00111111,,,,,,,,,,
,25.15,840,92.0,1.6,00111111,,,,,,,,,,
,25.55,840,93.0,0.0,00111111,,,,,,,,,,
,25.95,840,92.0,-0.8,00111111,,,,,,,,,,
,26.35,840,93.0,-1.6,00111111,,,,,,,,,,
,26.75,840,93.0,-2.3,00111111,,,,,,,,,,
,27.15,840,93.0,-1.6,00111111,,,,,,,,,,
,27.55,840,93.0,-0.8,00111111,,,,,,,,,,
,27.95,840,92.0,0.0,00111111,,,,,,,,,,
,28.35,840,93.0,1.6,00111111,,,,,,,,,,
,28.75,840,92.0,0.0,00111111,,,,,,,,,,
,29.15,840,93.0,-0.8,00111111,,,,,,,,,,
,29.55,840,93.0,-1.6,00111111,,,,,,,,,,
,29.95,840,93.0,-2.3,00111111,,,,,,,,,,
,30.46,840,93.0,-3.1,00111111,,,,,,,,,,
,30.96,840,93.0,-0.8,00111111,,,,,,,,,,
,31.36,840,93.0,0.0,00111111,,,,,,,,,,
,31.85,840,93.0,1.6,00111111,,,,,,,,,,
,32.25,840,92.0,2.3,00111111,,,,,,,,,,
,32.65,840,93.0,0.8,00111111,,,,,,,,,,
,33.05,840,93.0,0.0,00111111,,,,,,,,,,
,33.45,840,93.0,-0.8,00111111,,,,,,,,,,
,33.85,840,93.0,-1.6,00111111,,,,,,,,,,
,34.25,840,92.0,-2.3,00111111,,,,,,,,,,
,34.65,840,92.0,-1.6,00111111,,,,,,,,,,
,35.05,840,93.0,0.0,00111111,,,,,,,,,,
,35.45,840,93.0,0.8,00111111,,,,,,,,,,
,35.85,840,92.0,1.6,00111111,,,,,,,,,,
,36.25,840,93.0,2.3,00111111,,,,,,,,,,
,36.75,840,92.0,-0.8,00111111,,,,,,,,,,
,37.15,840,92.0,-1.6,00111111,,,,,,,,,,
,37.55,840,93.0,-2.3,00111111,,,,,,,,,,
,38.06,840,92.0,-3.1,00111111,,,,,,,,,,
,38.46,840,92.0,-1.6,00111111,,,,,,,,,,
,38.86,840,93.0,-0.8,00111111,,,,,,,,,,
,39.26,840,93.0,0.0,00111111,,,,,,,,,,
,39.66,840,93.0,0.8,00111111,,,,,,,,,,
,40.06,840,92.0,1.6,00111111,,,,,,,,,,
,40.46,840,93.0,0.0,00111111,,,,,,,,,,
,40.86,840,92.0,-0.8,00111111,,,,,,,,,,
,41.26,840,92.0,-1.6,00111111,,,,,,,,,,
,41.66,840,92.0,-2.3,00111111,,,,,,,,,,
,42.06,840,93.0,0.0,00111111,,,,,,,,,,
,42.46,840,93.0,0.8,00111111,,,,,,,,,,
,42.86,840,93.0,1.6,00111111,,,,,,,,,,
,43.26,840,93.0,2.3,00111111,,,,,,,,,,
,43.66,840,92.0,0.0,00111111,,,,,,,,,,
,44.15,840,93.0,-1.6,00111111,,,,,,,,,,
,44.55,840,93.0,-2.3,00111111,,,,,,,,,,
,45.05,840,92.0,0.0,00111111,,,,,,,,,,
,45.45,840,93.0,0.8,00111111,,,,,,,,,,
,45.85,840,93.0,1.6,00111111,,,,,,,,,,
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
true and possible, but injector sizing is way off i think also as a guess
tinternet tuning eh!!
:lol:
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Code:
if its erratic, then do as wilko suggests, and look for leaks
you reduced the % from 100 to reduce the fueling... so on idle you would look to add fueling so lambda trim does'nt have to. you will see block 032 cycle and increment as it tries to adapt.. +/-25% is the max 001 can cycle before resetting and trying again
