Just a few more logs after fitting the NewSouth intake gasket..
Outside temp of 3'C.
This is the 3rd run due to loss of traction on the first two runs
Code:
Group A: '003 Group B: '020
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME
STAMP /min g/s % °BTDC STAMP CF CF CF CF
0.01 3040 34.25 18.4 30.8 0.42 0 0 0 0
0.91 3320 91.03 100 15.8 1.41 0 0 0 0
1.82 3720 125.67 100 12 2.22 0 0 0 1.5
2.72 4240 163.14 100 12.8 3.23 1.5 3 1.5 3
3.74 4760 160.92 100 16.5 4.14 1.5 3 1.5 3
4.64 5120 161.97 99.6 15.8 5.04 1.5 3 1.5 3
5.45 5480 184.44 100 12.8 5.85 0.8 2.3 0.8 2.3
6.35 5840 186.42 100 18 6.75 0.8 2.3 0.8 2.3
7.26 6160 187.08 100 18.8 7.76 0 0.8 0 0.8
8.16 6400 187.5 100 15 8.56 0 0 0 0
8.97 6640 190.78 100 13.5 9.47 0 0 0
4th run..
Code:
Group A: '118 Group B: '031
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Lambda Factor Lambda Factor
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME
STAMP /min °C % mbar STAMP
0.01 3400 11 0 1320 0.5 0.883 1
0.9 3640 12 67.1 1760 1.31 0.984 1
1.81 4080 11 85.1 2070 2.21 0.977 1
2.61 4480 11 85.5 2190 3.01 0.93 0.922
3.42 4920 11 78 1880 3.81 0.875 0.883
4.22 5240 12 87.5 2000 4.62 0.86 0.875
5.04 5640 12 87.5 1890 5.44 0.86 0.875
5.84 5880 14 87.5 1870 6.24 0.852 0.875
6.64 6120 15 87.5 1860 7.04 0.875 0.875
7.44 6440 16 87.5 1890 7.85 0.852 0.836
8.35 6640 18 87.5 1860 8.75 0.836 0.828
6th and final run due to lack of traction on 5th run..
Code:
Group A: '115 Group B: '020
Engine Speed Engine Load Spec. Boost Actual Boost Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
STAMP /min % mbar mbar STAMP CF CF CF CF
0.51 3320 85.1 1630 1250 0.01 0 0 0 0
1.39 3640 73.3 1900 1730 0.99 0 0 0 0
2.21 4080 85.1 2070 2300 1.79 0 0 0 0
3.21 4600 85.9 1980 2180 2.72 1.5 3 3 4.5
4.01 5000 87.1 1960 2090 3.61 3 3 4.5 6
4.81 5320 87.5 2010 2000 4.42 3 3 4.5 6
5.61 5640 87.5 2040 1940 5.22 3 3 4.5 6
6.43 5960 87.5 1990 1880 6.03 2.3 2.3 3.8 5.3
7.23 6200 87.5 1920 1840 6.83 2.3 1.5 3.8 4.5
8.14 6440 87.5 1840 1810 7.65 1.5 1.5 3 4.5
9.05 6640 87.5 1820 1810 8.54 0.8 0.8 2.3 3
I have a coolant temp sensor fault too (new one on order). Not sure if it would effect temps at all but after the last, but after the last run I plugged the Scangauge back in and it was showing coolant temp @ 99'C
I've not seen coolant temp go above 87'C before...
Inlet manifold was cool when I checked once I got home
