Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Just a few more logs after fitting the NewSouth intake gasket..
Outside temp of 3'C.
This is the 3rd run due to loss of traction on the first two runs :rolleyes:
Code:
Group A:	'003				Group B:	'020
	Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
0.01	3040	34.25	18.4	30.8	0.42	0	0	0	0
0.91	3320	91.03	100	15.8	1.41	0	0	0	0
1.82	3720	125.67	100	12	2.22	0	0	0	1.5
2.72	4240	163.14	100	12.8	3.23	1.5	3	1.5	3
3.74	4760	160.92	100	16.5	4.14	1.5	3	1.5	3
4.64	5120	161.97	99.6	15.8	5.04	1.5	3	1.5	3
5.45	5480	184.44	100	12.8	5.85	0.8	2.3	0.8	2.3
6.35	5840	186.42	100	18	6.75	0.8	2.3	0.8	2.3
7.26	6160	187.08	100	18.8	7.76	0	0.8	0	0.8
8.16	6400	187.5	100	15	8.56	0	0	0	0
8.97	6640	190.78	100	13.5	9.47	0	0	0
4th run..
Code:
Group A:	'118				Group B:	'031
	Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost		Lambda Factor	Lambda Factor
TIME	700-6800 RPM	<=110 C	0-100% 	<=1800 mbar	TIME
STAMP	 /min	°C	%	 mbar	STAMP
0.01	3400	11	0	1320	0.5	0.883	1
0.9	3640	12	67.1	1760	1.31	0.984	1
1.81	4080	11	85.1	2070	2.21	0.977	1
2.61	4480	11	85.5	2190	3.01	0.93	0.922
3.42	4920	11	78	1880	3.81	0.875	0.883
4.22	5240	12	87.5	2000	4.62	0.86	0.875
5.04	5640	12	87.5	1890	5.44	0.86	0.875
5.84	5880	14	87.5	1870	6.24	0.852	0.875
6.64	6120	15	87.5	1860	7.04	0.875	0.875
7.44	6440	16	87.5	1890	7.85	0.852	0.836
8.35	6640	18	87.5	1860	8.75	0.836	0.828
6th and final run due to lack of traction on 5th run..
Code:
Group A:	'115				Group B:	'020
	Engine Speed	Engine Load	Spec. Boost	Actual Boost		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar	TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	 CF	 CF	 CF	 CF
0.51	3320	85.1	1630	1250	0.01	0	0	0	0
1.39	3640	73.3	1900	1730	0.99	0	0	0	0
2.21	4080	85.1	2070	2300	1.79	0	0	0	0
3.21	4600	85.9	1980	2180	2.72	1.5	3	3	4.5
4.01	5000	87.1	1960	2090	3.61	3	3	4.5	6
4.81	5320	87.5	2010	2000	4.42	3	3	4.5	6
5.61	5640	87.5	2040	1940	5.22	3	3	4.5	6
6.43	5960	87.5	1990	1880	6.03	2.3	2.3	3.8	5.3
7.23	6200	87.5	1920	1840	6.83	2.3	1.5	3.8	4.5
8.14	6440	87.5	1840	1810	7.65	1.5	1.5	3	4.5
9.05	6640	87.5	1820	1810	8.54	0.8	0.8	2.3	3
I have a coolant temp sensor fault too (new one on order). Not sure if it would effect temps at all but after the last, but after the last run I plugged the Scangauge back in and it was showing coolant temp @ 99'C :blink: I've not seen coolant temp go above 87'C before...
Inlet manifold was cool when I checked once I got home :)
Damoegan
Oct 15, 2007
8,993
Newcastle
Nothing camparable realy James, as I didn't do any before I fitted the gasket.
Last intake temps I logged was on 21st July last year. So outside temp must of been circa 15'C then but here it is anyway..
Code:
Group A:	'118
0.4	3400	26	85.1	2020
1.31	3920	25	85.1	2260
2.11	4200	24	85.1	2050
2.93	4560	25	85.5	2110
3.84	4960	26	87.1	2050
4.73	5320	27	87.5	1910
5.63	5600	28	87.5	1900
6.45	5920	29	87.5	1840
7.25	6120	30	87.5	1830
8.16	6320	31	87.5	1810
9.07	6560	32	87.5	1750
But if you look at the 4th run of the new logs you can see that the inlet temp only rises by 7'C throughout the power run, which is good if you ask me.
Also remember that my intercooler setup is all standard, not even larger pipework..
Damoegan
Oct 15, 2007
8,993
Newcastle
All I can think of is that by the time I did the last log I had already done 5 hard runs so there was some serious heat in the engine.
Damoegan
Oct 15, 2007
8,993
Newcastle
Filth......
Realy need to give the car a good clean soon :redface:
Damoegan
Oct 15, 2007
8,993
Newcastle
I've had a dodgey coolant temp sensor that has been getting worse lately (P118 code getting logged every few days) so fitted a new one today :)
Also services my 007P while I was on so its nice and clean for the track day :)
Oh, and this turned up today :D
Damoegan
Oct 15, 2007
8,993
Newcastle
Yea, it has been fitted to a car for 3 months but the car has never moved since it had been fitted. So it is sort of scond hand.
I have inspected it and its is perfect, nothing to worry about :)
