james walker
cooling is the key people
May 24, 2007
5,121
retford notts
with al the mods youve been doing damien, can you explain how its allowed the timing add ons, got fmic to do wednesday... what did oyu add for the seat sport and ive got a huge jetex filter on the way for some more g/s.
does adding the timing agree with your p-torque map?
what timing advance you on just now?
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
The Seat Sport FMIC is standard on the mk4 Cupra, James, so not even touched it.
My car was stage 2 mapped with the standard exhaust on (still made 225-229bhp though :)) so Will prob reduced the timing compaired to a normal stage 2 map. Once I fitted the Miltek system I then had a logging session and there was room for improvement so added 1.5' of timing. That lot freed up 8-12bhp (last RR was 237bhp).
Since then I added a better filter and done some logging and there is now better airflow so allowed for more advance to be added.
So I'm now running 2.25' of advance timing on top of my stage 2 map and I'm pulling 190-192g/s consistently.
Adding timing is not map specific mate so it works fine with my map and any other map.
Once the weather warms up I might have to reduce the timing though (TBC with logging). At the mo I'm seeing sub 20'C inlet temps while logging (also recently added a NewSouth power intake gasket too).
james walker
May 24, 2007
5,121
retford notts
considering the newsouth to go with my newly aquired fmic.
recommend this over bills? thought bills was a better option, thicker?
did the newsouth require longer manny bolts?
have you a rough guide on fitment, like to be prepared??
Damoegan
Oct 15, 2007
8,993
Newcastle
Cant comment on Bills gasket as I've not even seen one.
All you need is a 5mm & 8mm allen ket and a 10mm socket & extension and a 10mm spanner. No longer bolts required. If you have a look at it you can see how easy it looks, and it is actualy that easy. Undo all the allen bolts, then undo the two 10mm nuts, and one bolt under the front of the mani that secures it to a bracket. Lift mani off the 2 studs, swop gaskets and bolt back up. The bolt under the mani doesn't go back in though and everyone just leaves it out, nothing to worry about.
james walker
May 24, 2007
5,121
retford notts
adeas on torque settings for manny allen bolts or just ft
Damoegan
Oct 15, 2007
8,993
Newcastle
Serviced my 007p the other day and the car didn't feel quite right and the DV sounded different and vac was a little low too. So I stripped it again today and found that I had nipped one of the internal seals, therefore the piston was not sitting correctly. Lucky I kept the old seals so put one back it. Now running spot on again :D
Also fitted a new coolant temp sensor the other day as I was getting a CTS code every few days which I thought was causing some cf's on my last set of logs.
So with the new CTS fitted and DV sorted I thought I'd do a few quick logs :)
Still at 2.25' of timing
Code:
Group A:	'002				Group B:	'020
	Idle speed	Engine load	Inj. period	Air mass in		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s	TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
0.36	2920	147.4	14.62	95.03	0	0	0	0	0
1.17	3240	154.9	15.3	90.5	0.76	0	0	0	0
1.97	3640	191.7	20.06	142.22	1.57	0	0	0	0
2.77	4080	191.7	19.72	151.56	2.37	0	1.5	0	1.5
3.57	4480	191.7	21.76	161.31	3.17	0	3	0	1.5
4.48	4880	179.7	21.08	170.08	3.99	0	3	1.5	3
5.4	5280	173.7	21.08	175.11	4.9	0	3	1.5	3
6.31	5640	168.4	20.06	178.36	5.89	0	2.3	0.8	2.3
7.11	5960	160.9	19.04	178.64	6.71	0	2.3	0.8	2.3
8.02	6240	153.4	18.02	181.19	7.62	0	1.5	0	1.5
8.82	6400	153.4	18.36	182.92	8.42	0	1.5	0	1.5
9.71	6600	147.4	17.68	184.86	9.22	0	0	0	0
10.53	6760	139.8	16.66	187.19	10.13	0	0	1.5	0
Code:
Group A:	'003				Group B:	'020
	Idle speed	Air mass in	Throt Angle	Ignit Angle		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME	700-820 rpm	2.0-4.5 g/s	0.2-4.0%	0-12 BTDC	TIME
STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
0.4	3320	92.28	81.6	24.8	0.01	0	0	0	0
1.31	3680	137.22	100	12	0.82	0	0.8	0	0
2.22	4160	152.47	100	13.5	1.73	0	0.8	0	0
3.02	4600	163.14	100	17.3	2.62	1.5	2.3	1.5	3
3.84	4960	168.75	100	10.5	3.44	1.5	2.3	1.5	3
4.74	5320	172.75	100	16.5	4.34	1.5	2.3	1.5	3
5.53	5640	175.92	100	18.8	5.14	1.5	1.5	1.5	2.3
6.35	5960	178.94	100	14.3	5.95	0.8	1.5	0.8	2.3
7.15	6200	181.47	100	16.5	6.75	0	0.8	0	1.5
7.97	6400	184.36	100	14.3	7.55	0	0.8	0	1.5
8.85	6600	184.36	100	16.5	8.46	0	0	0	3
9.66	6800	183.67	100	18	9.26	0	0	0	3
Then up to 3' of timing
Code:
0.79	3080	128.6	13.94	88.64	0.37	0	0	0	0
1.8	3440	151.9	15.3	99.08	1.3	0	0	0	0
2.69	3880	191.7	19.72	145.78	2.29	0	0	0	0
3.51	4320	191.7	20.74	158.36	3.11	0	0	1.5	3
4.31	4720	187.2	20.74	168	3.91	0	1.5	3	4.5
5.12	5080	175.9	21.08	169.81	4.71	1.5	1.5	4.5	4.5
5.92	5400	170.7	20.4	172.97	5.52	1.5	1.5	4.5	4.5
6.72	5720	160.2	19.38	172.97	6.32	1.5	2.3	3.8	3.8
7.52	6000	154.9	18.36	179.22	7.12	0.8	2.3	3.8	3.8
8.32	6240	154.1	18.36	180.14	7.94	0.8	3.8	3	3
9.23	6480	148.1	17.34	182.33	8.74	0	3.8	3	3
10.05	6680	139.8	16.32	182.28	9.65	0	1.5	1.5	0.8
10.85	6840	139.8	16.66	185.5	10.45	0	0	0	0
I then put it back to 2.25'..
Looks even batter that the last set :)
james walker
May 24, 2007
5,121
retford notts
looking good damien, hopefully mine will be similar when my fmic goes on tomorrow, phenolic gasket thursday and the jetex to follow.
Damoegan
Oct 15, 2007
8,993
Newcastle
I'm going to leave it @ 2.25' and add some octane booster in for the track day on Sat :D
Also got a MBC on order so will be trying that out very soon too ;)
RpR
172
Denmark
You're not scared of detonation running it that close to the ignition's auto-retard limit?
While I haven't logged mine after I had it mapped for 99 octane Vpower, and I suspect it's running close to your ignition timings, although I'm running a bit more boost.
I wouldn't feel safe if my engine was running way into the CF's, especially now where the weather is really cold, it'll be a lot hotter during the summer.
Talking about big filters:
http://rpr.endoftheinternet.org/pics/pictures/ibiza/AEM filter (2).JPG
I should prolly log that baby ;-)
Damoegan
Oct 15, 2007
8,993
Newcastle
My cf's are at a very safe limit. Come the warmer weather I'll re-log and adjust timing accordingly :)
It feels great at the mo too :D
It would be good to see what airflow your flowing with that filter :)
RpR
172
Denmark
AEM DryFlow, I think the yanks measure that thing in feet, not inches :lol:
Prolly meant for a performance truck of some sort, fits the Ibiza perfect though!
RpR
172
Denmark
Small update: According to Andy at Rosstech the 1.8T can handle up to 12 degrees of retarding on the ignition, so you should indeed be perfectly safe ^^
He recommends to aim for a rough 3 around the board. Too much and the engine will start retarding heavily, as in a 12 degree retard, which is prolly around 20-25BHP lost the second it starts knocking.
As far as I can figure out the ME7 ECU our cars run will advance ignition carefully by 0.75 degrees every second until it sees knocking again, then fall back another 12 degrees, and so on. This will usually be seen as a choppy dyno run when reaching max boost.
The tolerance that will trigger that 12 degree retard would appear to be customizable by whoever wrote the software for the ECU, as in, the pro tuners who know a lot more about this than us :p
Dunno if they actually fiddle with the tolerance for knocking, I wouldn't.
Damoegan
Oct 15, 2007
8,993
Newcastle
R-Spec MBC turned up today :)
Fitted and roughly set to 1.5 Bar, but not had time to do any logging. Will hopefully do some tomorrow after work.
Also gave the car a much needed clean for the track day on Sat....
Seat covers off for the first time in about a year....
Also got a job interview on Friday @ 13:00-13:30 :D (straight down to Crewe after it :))
