Bondiblu's Mk4 Tdi
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
wow.
What did you use to clean it?
and for the dremel work, how did you proceed? how much of metal did you get of and on much places?
As above, the hardest part was removal of the bits, as most of it sits between the engine and the "firewall/cabin" so access space is limited. The job isn't too hard, just time consuming.
Once the manifold and EGR were off I soaked them overnight in a decent degreaser/engine cleaner to help remove some of the "gunk" and then attacked it with paint brushes and old tooth brushes till fairly clean.
With the dremel I ended up opening the holes to match the gasket (on the engine side) and just took a bit off on the EGR side. I did have quite a big pile of aluminium shavings at the end of it.
search google for "porting and polishing tips", just remember, rather take off too little than too much.
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
What I should have done is a " How To Guide"
and if anyones interested, my original Cupra manifold and an EGR are in the "Accessories for Sale" section.
Means you can prepare them before hand then all you've got to worry about is the swap when the time comes,
Then sell em on again like I'm doing ;)
1,892
Derby
Well i removed my EGR after 90k i thought it would be really bad but it wasnt so a quick clean out and bolted back on i really want to take my manifold of and do that might wait till it comes up to 100k then take car of road for a bit and strip clean and rebuild it
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
A little treat!!!
Thought it was about time the "Beast" had a little treat after labouring so hard.
The plan is to do them after work today, weather dependent
Edit
These are ARB bushes and drop-links
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
I'm not sure myself but if you do change the bushes you will have to re-balance the car else your tyres will run flat in no time
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
Those bushes, they look like the ARB bushes? Or are they the wishbone bushes?
If they're ARB bushes then you need to get the ARB off, however you won't need to get the tracking checked.
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Yes they're ARB bushes and drop-links. Why would I need to get the ARB off?
I've changed them on a MK4 golf, that was easy, was just wondering if access to them on the Ibiza without dropping the subframe was possible?
Anyone changed theirs themself?
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
I stand corrected, I thought they were wishbone ones :)
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
Heh it's ok, I should of figured it out as they do look quite different to the ones I had fitted to mine lately :)
Blanco92
Apr 11, 2010
2,496
Well I changed the entire ARB on mine and did the bushes at the same time, so yes I dropped the subframe. Hint - the ARB comes out easier on the right hand side (UK driver's side) if you do end up taking the ARB off.
You can change the bushes without taking the ARB off as long as you can physically reach them, it'll be tight, but I reckon you can probably reach them.
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Didn't get a chance to do em but had a quick look under, appears there is sufficient access, and looks easy, appears to be 2 bolts holding the bracket on, job done, and I'll fit the new drop links while I'm there, hopefully my little knock in the front will be gone.
All comments appreciated, I'll post up how I get on.
adam_may
193
Sheffield
let me know if your little knock goes as i have fitted new drop links but mines still there so must be the ARB bushes!
dangriff
I'd be interested to hear how you get on changing the bushes without dropping the subframe and removing the ARB, so if you could keep us posted with any tips or pointers that would be great, also any ideas on the price difference between the powerflex / OEM bushes?
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
I'll defo post up my findings. It's on the cards for tomorrow evening.
Regarding prices, the poly ones cost approximately £30 shipped verses just a few pound for OEM Ones
Bondiblu
Enthusiast
Mar 18, 2007
1,648
Cheshire
Ok finally got around to doing them, and yay success, my knocking noises from the front are no more. Found the the front right droplink worn and both bushes were worn.
This all done on my iPhone, so excuse the quality and any typos
It wasn't hard to do, just access to the bolts isn't ideal, but all done and dusted, next job is to tackle the back.
adam_may
193
Sheffield
Well i have just replaced my droplinks and i still have a little knock so im guessing it must be the antiroll bar bushes then! how do u get the bushes onto the antiroll bar? is there a split in them?
