Am i driving a Leon or a sieve? Another water leak : ( Please Help
t32er
And you have no problems with steamed up windows at all?
nope
didnt on the cupra after i dryed it all out
started to get a bit of a steamy boot window but found water in the boot so thats my next fix but up till monday of this week no issues, even tested it with buckets of water and all seems fine
Feb 28, 2010
1,367
Southampton
Sweet! Ive noticed my rear boot lights are misting up - silly leaky car! any hints on that one?
HAHA Got sunday cut out for me then rather than the BTCC!!
t32er
iv not found the leak yes just see the fishes swimming around lol
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
i cut all the wy through the rubber both top and bottome layers other wise it will just sit there and find its way back in to the car
when i get home i will try and get a propper pic of mine
i dont get wet feet when i open the door, the water doest sit in there any more
good man cheers t32er!
tomorrows job :D
What happened to the pic :(
Im going to try doing the seals in the door first and see how i go before i start cutting out triangles in the seals. Wish me luck. :blink:
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Started working on my car and already back on the forums asking for help. :blink:
Well i say started im stuck at the first part of trying to remove the handle???:shrug:
What do i use as a screw driver will mash the plastic up right? What should i use? Some thing flat to get between the middle of the plastic the leaver up??? Any helpful hits please?
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
Use a thin screwdriver underneath where the two halfs join. when enough use your fingers or something else to pull them apart.
Ok Cheers mate will give it another go... just worried about snapping something :-o
Take 2 here we go.... :rolleyes:
Cheers Lee
leontdi130
277
Euxton (Chorley)
i've been having issues with my car filling up and steaming up inside. I attacked it the other week and dried it all out or so i thought. But t kept steaming up so i pulled the trim off in the back and pulled the carpet up. Even though the carpet was dry the thick insulation underneith was drenched. when i lifted that i had half an inch of water sat in the bottom of my car. so it ended up with the seats out so i could get the insulation out. I had to cut it with a stanley where it went over the tunnel in the middle. But if your car is still steaming up or smells damp its probably because its carring its body weight in water around with it!
TubbyTwo
Taking a break from JDM..
Jan 27, 2010
957
Ipswich, Suffolk
Right seal trimmed and carpet vaxed.
Will see how we get on. Wash the car after modifying the seal. Blasted it with the hose and tipped several buckets of water over the drivers door. So far so good. :D
oldskool
you reckon its done it tubby? Has it sealed. Can you put a pic up of your slits please as tez has been lazy again lol. I am goin to attack the seals tomorrow. Finally! Did you use a stanley knife?
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
519
Swindon
What a long day, managed to get the seals done without to much trouble, hardest part was trying to take off the door handles which Lee helped me with
Then spend most of the time pulling up the carpet and sponging up about a 3 pints worth of water up which was not much fun as its really soaked in... but will try and dry out with one of those Dehumidifier.
Thanks to all for the help, saved me lots of money by not taking it down the stealer to be fixed. Also made that end of the day pint down the pub even more deserving / sweeter :happy:
As i received so much help from you lot i thought i would be helpful back by taking a load of pics Enjoy
Seal Cord box £32 for 10m
Seal Cord
Removing handle with plastic bike tyre leaver and flat-head screw driver
Door trim off
Old foam Seal not really sticking and perished as you go along towards speaker
Lack of seal under speaker, can fit screw driver between
Removed Old Seal and cleaned up ready for new seal.
New Seal Cord
Job Done!
Dare i say it.... Bring on the rain ; )
Thanks again 2 all!
TubbyTwo
Jan 27, 2010
957
Ipswich, Suffolk
will get a pic up in the morning bud, yep stanley knife, its not too hard to cut.
G1NG3R
well i'm gonna be busy tomorrow looking at this not only have i got to lower my mates cupra and do his do his sills i have to do mine to now.!!!! i think i have a few frogs on lilly pads in the pond in my 2 rear footwells nothing in the front though.?
