Cooler looks like new, awesome job that. Are you fitting the cooler yourself? I hate these front bumpers, they come off alright but like to be a pig to go back on
Cheers, yeah it was a doddle really, just gave it a blast with some citrus aerosol degreaser, waited til it dried then a light spraying with the paint. Only did the front, didn't bother with the bottom, top, rear or the sides of the end tanks as they won't really be seen.
I'll be fitting it myself, yes, with a mate. I've been given a top tip for removing and refitting the bumper easier, I'll try and take plenty of photos while the job progresses so it's documented
Yeah cooler's make no real difference to insurance I've found which is handy
Looks good stealthy black mate, love it, similar finish to my Airtec.
Look forward to seeing how you get on fit it and find the drive after. Might be worth doing a TB reset through vagcom after you've fitted it just to
help it adjust.
Cheers Tom, yeah I'm with Adrian Flux who've been ace so far. I like the look of the black Airtec cooler and was almost away to order one but when this came up at about half the price it was too good to pass up
I've got the Forge MAP pipe to fit and a pre-trimmed battery tray too so the battery will be removed for a bit to fit those before doing the FMIC which should clear the ECU adaptions. I'll need to get round to cleaning the throttle body soon too so will do that then. I've also been told recently that apparently rotating the TB 90 degrees can benefit flow into the intake so will maybe give that a shot.
Fingers crossed it stops bloody raining and I get some time this weekend to crack on with this, very keen
