Updating the inbuilt Mib3 Satnav Offline
serdar_18fr
514
however if it's done via Vag tools and presumably license is paid then it fine. You will fine in Turkey there are cars being enabled for navigation that arrived for whatever reason.
Only if the local importer of VAG cars cared about selling official navigation licenses. Maybe in some other countries but not in Turkey.
Sent from my 24122RKC7G using Tapatalk
Tell
I think there are license issues why you don't get it in some parts or the local government won't accept "foreign" maps controlling cartography. The maps are available in some instances for the country but in mib format but not made available. Middle East is one. Turkey there might be border disputes. Korea foreign mapping services aren't allowed in for security. Japan is similar. Other countries they jam navigation. I've had that in Jordan you are going down a road to a destination and you loose position. Driving dark. You have to turn round till it locks back on and return back the way you came. Syria in that instances. They had blocked out anything near the border.
Tell
@Ammar2jz your friends car the PDF if it's the latest one:
You are looking for Navigation Discovery Pro on the spec
It is optional on the Comfortline and installed on the R-Line.
The VW Terramont is built on the MQB platform. It really dependents on the model. Prior to 2020 it will be Mib2. Mib3 on but may be old stock hanging about. R-Line is the luxury so you never know if you put the USB in it may take it. Otherwise, you are looking for a retrofitter if Mib3.
You could feed in the same details as you did to Mib helper to see whether it pins it down to mib2 or mib3. USB-C it's mib3... so you don't have to do what I said. If mib3 just try it with the USB drive. It won't hurt it.
Apr 13, 2025
Here you go this is a picture of the entertainment system
Tell
H67 is an interesting code. Have you tried the usb-c. ?.
The car could be one of those without navigation on the pdf. You could ask the dealer for a print out of the build codes. See what that says about navigation. Whether it's mentioned. If it's usb-c and the working usb doesn't take it then it's probably a job for a retrofitter.
serdar_18fr
514
I have never seen a case where it is as easy as inserting a usb stick with maps on it. Even if the hardware supports it, I don't think that the navigation FeCs are enabled.
Tell
Probably true but worth a go. Dealers will give the build codes then take it from there with a retrofitter if the guy really wants it. Retrofitter will also look up the car, if they can't do that then they are unlikely to be able to do the work. This is just like early days of mib2 high in the UK. You got to find a decent retrofitter like the boards sponsor. They will want to see that picture as well. All would not appear to be lost from the 5H6035832F device part but may not be activated for navigation.
Reactions: serdar_18fr
