ND-Photo.nl 's - Seat Leon ST Cupra 280
nd-photo.nl
4,386
473
The Netherlands
youtube.com
The original brake booster hose was cut for providing vacuum for the cutout valve, but I bought a brand new second hand item. I don't like when critical hoses are cut...:wtf:
I swapped over the MAP sensor for this hose from my car, as I have no idea how old this MAP sensor is. I also replaced the green O-ring for a brand new green nitril O-ring.
Partnr: 5Q0612041AR
AP1GczPa3P_hTJw839FiEhDIoDYA3JakLwycCU9gs-R3t2blWyiJh9Mn_XzOubybqTJmtnwKZaJIKQbm3FtQGMNmHPXq5G97LRmAqdDe-r6iI2Wd_3BvwM8diE2AVchztNPrmPW67v0fIr6HP4F4I9fEX4-3Mw=w1920-h1080-s-no-gm
AP1GczMfxEMbFLxcaKPVtFAaVPJr-IEOIBtBM3ZyCB83KOUa4uT9SbCmdHOuT5oB-mexo99dBlB0UyT0hUWY3-O-u-Ke_nNhhhqxwkIjPaVQ_XNxVo8EEhV_Dc1m2HNMjRDpQ6ma6vRVVmVgvSc8PtzWACkSTA=w1920-h1080-s-no-gm
AP1GczMFv8Jw3aGqSHeSvuvp1MsMy_DiSnJqevhdDnBh0mVeUgAZ6zY56sn1O34owaZalrAVPs38GFTSj1-7GHkN5hbQ11Lo5bkPnFcc6UetUqWfPUaqyt26aVKo6SNU23fRuk51hCV3k2c40XJ1GGrC-TcKtQ=w1920-h1080-s-no-gm
Michael_LeonV
63
23
@Michael_LeonV Let me know which gauge you picked :rocker:
Struggling to find one atm, as do not need it visible all the time, but looking at something like this one
that I can then connect and have it in the centre console, and place it somewhere visible when desired, as there isn't really the dash space to mount a 2" guage.
Reactions: nd-photo.nl
nd-photo.nl
4,386
473
The Netherlands
youtube.com
In the meantime I tried 2 other standalone vacuum pumps for the cutout valve, but both did not work correctly :shrug: So I decided to re-use the vacuum solenoid which was already in the car, but with some changes:
- Used black heavyduty / reinforced vacuum hose for the cutout valve, instead of cheap blue silicone hose
- Tapped vacuum from the turbo boost gauge line, instead of the brake booster hose
- Incorporated a one way check valve to prevent boost leaks, instead of not using a check valve
- Connected the solenoid to a switched 12v in the fusebox under the bonnet, instead of directly on the car battery
AP1GczMW24wAfoEYp2tQ8MG7f0xesM0rBuwRf-wPGfRWEiU0PoYKipE5e2etUKf5tb138oQXfWK7ImUA9HZf4GxJOah7JRz22aq8D2uf0hBaFZ8GwWfwe--Fqkidne6c5lPirbs9wMhJdI7q0z2MvhkCt2hUZw=w1920-h1080-s-no-gm
AP1GczNvjg7XguBOcow9oRP3NNQAyTj12ctcI5T95c2FhSCrgfCBDX1GGMJv8IlGOx82aeOm3rIbtECrBs2-z65FlNa8MFE-HN0irxTwg9Vzts1hD_sVrHsWMBXFJC_CF8AyM9LbPwCTGpZxUDVaF3oKpsHnRg=w1920-h1080-s-no-gm
nd-photo.nl
4,386
473
The Netherlands
youtube.com
Added a little heat management to the fuel feed hose. Unfortunately, I'm not very happy with the fitment, so I will have to see what I will do in the future. As petrol also cools, I wanted to help a little as the feed hose runs directly over the hot engine.
Most of the wrap isnt even visible. Its quite thick layered and has velcro at the edge for easy attachment.
On the right side of the HPFP you can also see the check valve for the vacuum solenoid (picture 2 & 3)
AP1GczM4IwqME2bkcF8o9EXZSXlB3NMbvkw26RPcaQr6QhQGPyTboJDja5tH3x8Ea6J4daisFU08LmYd3bUAKExRVupKI1E4N6wGfXihMSa1BlvmP-kTA8lhmjHEsDZyWLyFhjpMaCH0NhG_9_EjPS5mKoGWtQ=w1920-h1080-s-no-gm
AP1GczP_zgZgVixOT46JgVQ_a-bWwzhJECi3RG5qqxj2vhsnY_I-yKM-DyC2C_bE4B1AUX66JyvddZaKI1wUll-KodMK44jgsreBThrjMTZWPvwjLKI4hjpLLAmdgAEItzljW8kMa0aIbOE5oEOdJnSMgllf-w=w1920-h1080-s-no-gm
AP1GczPzUtSgRNmuUkwQ_yhUW9TmAsO5quGgsDiCoi1fzCgv5j_MM7Hjb1oKXSQjvk-HvYoaz6Ua9EiCqTylNlv0wmjeKbOctKk32w_hZiUK1I8_Z1AL9VjyXF5Uy_vMq-59xMdrZ8Rp78I7Pp6ttnp5EMF34g=w1920-h1080-s-no-gm
nd-photo.nl
4,386
473
The Netherlands
youtube.com
As I mentioned before, I wasn't totally satisfied with the oval tips. So I went ahead and took a little gamble on 2x round 101mm exhaust tips 😍 I was inspired by the Golf MK8 GTI and they worked out great!
AP1GczNaT1oyE5ysKOGIsmfWgKzliQqdmPKZjQSTM5wdzSQeHBTuw1waAQSB0CK5JS8EVpFifMDcoXJUY6a651uZrcIdStypgBR-fhlW_5IHTMOUc7eG91Pq-u5EH3ix9PU6-Xg3YEdbaDRqT_l0pHvi4Jawzw=w1920-h1080-s-no-gm
Fisting test approved 🙊
AP1GczNUJ4BmcEwhCsQ01qMszKgO-Jyu4srTZl_8RrwRHP4ch8AKJQYXXAOd_kxYcbXtu3vag0dfWaCVbDXLEsENlpCumLfUxYSj8It7xkNp2ntoEXjshvIjHGa4x-p4DTUL6LUJwrDdmBblpte26OUZ7wmY_w=w1920-h1080-s-no-gm
They are massive
AP1GczPRg548-yIsul8HK-X5xlkLdrRZ6FojsXTPHVS1OuM5NXNwIP2dJmOS3bW5ZXCNHmeP0dSfl5yFGdxXPIpZmgmR5PiQy1vLDldKOmaNs2RVev3Z6yetgz1WAaQEnR3P_Y4V7MdO_4y5FOpnTNYNXTrCug=w1920-h1080-s-no-gm
AP1GczPKxscsJ7iCIHae3accc3JtfkfMVbLUvKMozVueARoXl7GbUD6ji0-MzQJlIBMsZUjOPClV8uWfQbDL8k5UpVI8EkeZZ8wpPBLcQglDInLkpO6mSXWyQdcghICONnBJ7Q6y9Yt56tQrdZHqjpwVW5StWw=w1920-h1080-s-no-gm
Quality is nice, but not perfect. But at this price point, I am not complaining at all
AP1GczM51XZ5CNtFF0EhVCyOoWafLGVLBU1jeb-Fbb4nUrXZXwz0r1Tta1QWBtGM6GfldqwWopt96Qnff8E3lgnIlSMKbtkI8xaOz_1t6OAtHr_nsWriUWjnOGBBPAQBwABvaGH9R_OVkenYMrlbemFKQTwSew=w1920-h1080-s-no-gm
AP1GczMO1RsGuxaJ8xlKBjc_rCWt9R0yZfPyTF5KmGLir-gUz1or7Iu1tBFJhtOVRhQFVIpcQhmsgVLw4F2omkzvlXCUyzdPvhXeAsxz4J67Ufy3sEc1fEXr2hLRVfA_WDcubXu-qVsTJzEhyUiOIWmtNcMouw=w1920-h1080-s-no-gm
51mm inner diameter for the inlet side (ID)
AP1GczMG-MLACx6Uotzz7pDddHKKoyEObRrywAPAEg94MTHXURwU03nWvghHFM7YVHwYLPR0_hviU127-fOBhIs14MjaQQD4LMg9Lf26iUfkywbeNdT9goCEpDDaoeOKy6qt-IF_hxJ-Hg_wewC4rrBBzyQHjQ=w1920-h1080-s-no-gm
99mm inner diameter for the exhaust side (ID)
AP1GczOkcopADCb8gyDt9fGZqYnPNesrlFhEqZ56vp5Y3RN4P__V4-EgEZ459I-zCvSzl9Hk5wYaAm95o-IYWg4IXHBBbfkic_ZqaGAeZNSM2Vc7cxB8wJwuY30Hzt_2VG6h-D8xG3PBR59-kTkFY3KC7a0EHQ=w1920-h1080-s-no-gm
About 17cm in total length
AP1GczNS8QMvuCRwV7OO-lgJPIPcAe7w9jG_JeYcXnpeO4KHAwZxEIaq9NSAPa06HAfK-GguVXZXLg84yZF9m5Vxq9QCYfBVz9_Q6L1iKa-aMD3Qoo1sdwqODsWmxn_zxwyoiPjFqan1B7NGQxX2srgkAbVSKA=w1920-h1080-s-no-gm
Reactions: Mo_86
nd-photo.nl
4,386
473
The Netherlands
youtube.com
This was more or less me, after fitment :rofl:
Happy Little Girl GIF by Demic
AP1GczO4dCIxeHsA9oWEsC5xI_UfRINBfk9h1OlCnhMSZi9kjlqs51K9xL-JIUb2PzIHT_XYGk_r0Bid0nkkrpz_iTV9VyEEQHTj52SVsUSDoj2TiGgSCenBKJKaJk-aqgxxYe9nY53z6TkCKA9-OnZOD-cHnw=w1920-h1080-s-no-gm
AP1GczNuw_rlG1Konp71I74jHjMS9ZGAHf-1r-8xFUnTHkRKAWely1VugyhwJW4hvo4tcdlD0KEn6xDawTe5sbS3L6DvGJ6Jc5lPaLefxqkfjpBGwRYKAII9iGPQaG5j3xtfdHdYh8W3kCXD3Wt0wFdckiz7NA=w1920-h1080-s-no-gm
The inside of the tips need to become black. That will happen in time with carbon soot, no worries there
AP1GczP-YJnYHo0YAAwgxfB60nBPgqtm2HNwhFH1ymYXVpJNgnOzZyp-HyBvpjODRUTGUDqnmk_od_4dYhWDXIlp4TIBy7fUGdHZaLudoMX6z-P4PmnMSs6E6AEfNSNiDaHJuAWApqx7-jZqp6fJ6ozYiOo8qA=w1920-h1080-s-no-gm
I think it will look even better/more aggressive with the Rieger Tuning diffuser
Robert Redford Nod GIF
AP1GczNkPyxT6XKxAGU7gAkcqUHPezrILDqU_y2XsvUrq7IZtTGz59vUKclVA2frxR0GfmOMkEIABu9LGPBQQHo8QrADGRS0KYQar24VQenT0hRCaaa86ENYsP4oH5OhqMmDIZ5DwLk2Lu3MVVzglqnzStX3yg=w1920-h1080-s-no-gm
Looks even better in daylight hehe
AP1GczMdsz558r0KSJCR8VxjIEgWj41cLomcHlW3txyaB5ClchI7dxxBnUqXStPAT4lwfiWmxlPUYponD-h_Mikvnkq8E2jmxx5bHrz4VDQbzdQ-t4I28QuAIm_Q7h0a-OZYmnmYcMixRw57AtMT3VaLnccBFA=w1920-h1080-s-no-gm
nd-photo.nl
4,386
473
The Netherlands
youtube.com
I wanted to buy the DO88 intake, but I adjusted my goals a little bit. I want to see how well the Cupra responds to budget friendly mods. In the end I can always buy the more expensive "tried and tested" products right?
I found this type of intake on Aliexpress, but it seems I could also order it on a known dutch webshop. So I got it within a number of days and only cost me about 115 euro, which is a steal if it works well (y)
AP1GczPml6qmPdbSMODpyJAD4oTDLvBFxs1hbVSuDBax-8U6NzfCbXtbY48Ht2ALUkMqKjQKuan8TVIxD6ftHdsbG6zGaxU5Bf5I_a3OIDiI3uKOA_muflpfq62eDZRRf-TeKSgA3F0oP4_EnMI56Tl1FfscSw=w1920-h1080-s-no-gm
Filter looks and feels pretty cheap. Unfortunately no builtin velocity stack, which is to be expected at this price point
AP1GczMhoUHwluZiNRx8F3SJj5M7h5zJAOedOuRUkCMaWg4Ovgvn5MSixTMHo3lBiwWFtH2oZwwyykUzttMMUynO3oBQcePG4g3j44ZSuGRRcoQNGEGzF9ZMY2x5-rjN5qf5DikJ_UpbMpIBwxuOUTTt1LrmQg=w1920-h1080-s-no-gm
The tube looks great from the outside! Its a 3.5" tube, which is big
AP1GczOgTFod5E5dbMwfffYzS4WvKZLTmvngZ3ZcoOkpwm9bg0bI_92ZjULqUAj77EU122FV5yVpMG7ZZyAnYOhCyGicAdKPImltEF_e8MQGJOxxs0bZ5Jxl98bwXYpEu2PJv5Vm8PrySOk6XyZg6cSGaSaX5A=w1920-h1080-s-no-gm
But the insides show a big ridge on both sides where the pipes were welded together. Again, this is not a surprise at this price point. This might have some effect once you remap it, but I don't expect this to have negative impact on my stock Cupra. I wanted to grind it down, but there is way I could achieve this, not even with my smallest dremel accessoires...
AP1GczMkj97tqQcPMhh_NKuUQ6JSb7-OQVoVRkxcDOZRNc4lnQOnR6NAZHTszt788DDzF6pBoum7HOYvpS0JWvJhEW7fS6-hZ9D0RgQt-KyhXfTtg0qHI0fWMmoEHpEA97YFmAHDZrNEB3EOFvREbYWQbD5aBg=w1920-h1080-s-no-gm
AP1GczM-LEpTlpYAwD5QWYNvXpyQFXzBlbMtiPHyzlHJXVLUeOKN0qrcToeFJOl2HsVqRv1Xi4hktMs181sdc-Qf4w5_UxSpCkEj6lvzefmOxpDJo_06vSxE_7xF5a7h2abP0z6lvjGKXid3k9qZwtmd1kFCKg=w1920-h1080-s-no-gm
Overall quality looks nice, especially for only 115 euro
AP1GczOEaGMqDpTXYZgPKeHMOE-6wHqltjQW6FaWa19BadQUz_b6BhFYh8bincu_4ScJNUBEvMETF1165gA4RRgWdgNHo6H-e90iCahCzdldK0aUwZz_xRFl2LX-YtYWw9Evkopkith6rL5LjhaU1-qor6t-Ww=w1920-h1080-s-no-gm
Look at the major difference compared to the original intake tube :sleepy:
AP1GczMu2UUJJ0xmJ2YesZDwoi2uE30cbTw-uk0MFaSN2zv6EOEBQ0GGYtCKlYVM9bcKDJ3LgXowCwAndsTYr6J1TJdkSa5rOCvWTdLw3tM97JyhhAKlInmzNmZ66JLzmEKxxus2EbGChftkr0xPW9WRUZh8FQ=w1920-h1080-s-no-gm
Reactions: Mo_86
nd-photo.nl
4,386
473
The Netherlands
youtube.com
For a budget intake, this looks awesome :giggle: I already ordered another airfilter, which is still way cheaper than a proper aftermarket solution (+-450-500 euro on average)
AP1GczM1qw8xUpo6xDXeKwAzBibMVuH2JBOPSi2Ms9Qvcn85nu35o2tnebLdyktIA35i_5WAfFtV5QLLQCDBbaDWGYWz8eO9VnU28ag-SGY14q3weXZPEp8Y048L21HnTpyAXloxNZctube3hJOxaNyBX8IOuA=w1920-h1080-s-no-gm
AP1GczM0v1wb9LY1H4DVqY3cZu5CUT1Ynojpkm37Tb5Zi_MnYaqLJGoHQ1Ybnc1NALEd3vvtGSZLqdHm0O9ghNa7R8banUJz9NdlhCCL23JuZFNRPaNSy3JtxjL0d4UjE6L_p5f9rlNMzmyqngJZXQTcHZ4DSw=w1920-h1080-s-no-gm
AP1GczOyzPpOmnzD3ruxOQjwUBdOoPVQk46LYFIUHgZHdtvdhoqbdmKfJohMk52NM9bX7rYPXZbkE6R_XzCgd8YI7LjgG_Us_FDr5Ax3IhdrHlvsWQbJUt9mN_7Nzg0PndvZu018IELK4DYbPDVgX_SFSY3c2Q=w1920-h1080-s-no-gm
AP1GczOH9v3znL0tjCK4CR8KgmDey6c2iNtTaR6WLwrCOABPWiKw2GGL8Kwg8RAm-pJHG3SNj0LHB89wMytF8Mr9FH766yYrbmgiYnn_i2i2D43fLeLeZJmf-pRlnqXebR5-agTa97lNjJIskb7OtQhDUxOH3Q=w1920-h1080-s-no-gm
AP1GczMp23qecbEVJ2pc7n1NYJYtth-H763oXiefpztZXchO6gVLkwoqiKHIekW9xdWgFXkiQh3cp4Z0ovfwm0lLEJESUOj7t5nyn7k3xD0-Y3isx0z2c4vFp7VKvuo7WBSZPq1JKmUWtUQlYbNX0ss5DJ4W2w=w1920-h1080-s-no-gm
Measurements for choosing another air filter
AP1GczPv-mA7SiE6PwcFpx8zR_8Rs7sEmLhhqToodWYlMNqKi5OkA5BUBjlpAmP0o9WNOOZHlatScI3QXKwWOmsIBZ2Rrp67_thxo9iLhO-LoEt0HpfskGuHfFxbJ4cY9lJBpCCVPL01BNUKys_JXjJL852zoA=w1920-h1080-s-no-gm
AP1GczOll7_Aj9r6XPdLHbBRy1cnSidCfNYNscH_LS7Qc0FIEn9W6TuptW1xluwep-wjse8ApTKICsnvICmglV0_qPANlglrOXtXjW-AuXJO_GuHUG36FLHPraLQo0Z2aCnIarHuF9lmRJGleTW35D23Q7xf8A=w1920-h1080-s-no-gm
It sounds great! If you love induction (turbo sucking noises) and muffled blowoff, then go for an open intake.
Reactions: Mo_86
Bluepower
84
34
Mooi setje Andy, van welke NL shop komt deze?
