But there is no Music SD card inside... and no USB...Yes the mib2 standard firmware isn't the bees knees it allows memory mismanagement we did get it once in the Arona. I pinned it down. That was due to embedded JPEGs in the music file being played in the unit. They are suppose to be circa 512x512. You would not expect a large jpeg breaking that parameter to reboot the system.
First I thought it was a corrupt mapcard. Pulled it out, tried another one I'd got, same issue. Not the map card. Next tried it without playing the SD music card, it worked. Then pinned it down to a track / album. It was off the net someone had embedded a 1,000 x 1,000 jpeg image in the track. Well fine on a home system but not on a mib2 standard where the programmer hadn't made an allowance for that. You'd go can I load this image into memory, yes/no. No don't load it in. They had gone yes and had produced memory overflow where it crashes the system.
This issue will come up on mp3 and FLAC libraries. There are programs you can run to delete the embedded jpeg and then put your own image as say cover.jpg in the album directory no bigger than 512×512. I've got a post where I name that program on the board, it was used a lot in the past.
I cover my problem here and solution:
Media Issues (or user error)
I should clarify "then right click the artwork "box" (which will be empty)" It is "empty" because you have selected multiple tracks from multiple albums, the reality is that the Artwork is actually preserved for each individual track and/or album. So by "right clicking" the "empty" artwork box...www.seatcupra.net
It might be that issue. You have to see whether it reboots not playing music but just navigation. No music or navigation. If rebooting on navigation alone it will be a corrupt SD card. Buy another VAG one. Any brand.
You can put the unit in demo for navigation, under advanced. Engine off and just wait for the unit to reboot. That's what I did in the diagnosis of the issue going through those alternatives.
How can I put a demo or a replace mode if the screen is not touchable? Is there a direct method?
I would like to know if is possible to enter in recovery mode and install a new firmware (also, which is the correct one? the Infotainment is similar at the one in the photo... Seat Leon Xperience 2018).
Thank Yoy so much for the reply
