MIB2/MHI2 Harman High - MHI2_ER_SEG11_P4709_1_MU1447 - AIO FW update & ifs-root Patch (ASI, CarPlay, Android Auto, Map Update)
cairus
361
123
Was on the car with vcds today. Was able to enter and acknowledge the version conflict with the new checksum without any problems.
leonlad
1,155
51
london
trying to force a firmware update on a mhi2 but it refuses to install all modules it only updates one module to look like firmware has installed correctly but it is not how can i force to do a full install tried swdl select all but does not switch to Y
leonlad
1,155
51
london
That's going to be the boot loader only wanting to load up Skoda firmware ?. Wonder what happens if you open it up and do that pin short trick whether that's helpful or whether it reverts back to Skoda only. Don't take my word for it.
i actually got some seat firmware on it but it does not work properly, i think i stupidly jumped the wrong train also the unit is h42 0318 firmware
i managed to get in to the emergency flash tool but it will not accept any firmware on sd card or usb. complains about train info variant mismatch when trying from the update method. i wonder if the metainfo needs to be edited so it does a full install of the original firmware.
Tell
We did have @Chillout in our ranks once. He'd know.
Oct 18, 2024
13
Little offtop but does anybody know how much amperage could usb deliver in leon 3?
Mine can't even maintain phone %; its slowly dropping; not sure exact number maybe ill check tomorrow. The one that support carplay have more output?
I'm looking for wireless AA box and I don't even know if usb will have enough power to run it..
Tell
I can answer a bit of that. The mib2 high units divide into two or whatever. Pre smartphones 1amp was all you needed. Those early version mib2 high set ups only put 1amp out. You know this since on an Android smartphone it will tell you it's not taking the full charge and that % battery falls.
2018 or so they changed things around and 2amps is output. This might be where I call @East Yorkshire Retrofits for the knowledge. It could be the usb socket unit that needs changing to get the higher amps. Either way this changed as VAG realised that earlier systems designed for non smartphone were no good enough for running the smartphone with AA or Carplay enabled.
I'm a Luddite about AA / Car Play I don't use it on my Ateca that puts out 1amp on that socket. I do have a 2amp 12 voltage adapter but that doesn't pipe the data just keeps the phone / tablet running and fully charged. The Arona with mib2 standard which we have also have (2019 model) does output 2amps so I plug it in up the front.
It's wireless charging that you may want. I don't think you'll get AAW as it's called (pretty definite think its missing the chipset on older models). That uses a dual band wifi 2.4/5 ghz. Your old unit won't support that. You need to stick to USB for the data link. Now whether you can change the USB socket to give you that at ~ 2amps. One for our retrofitter friends ditto a charging pad ?. You do see threads about on the board discussing wireless charging and solutions.
Oct 18, 2024
13
By wireless aa i have on mind boxes that plugs into usb (you connect to them wirelessly and it gives data thru usb to car)
If port is creating 5v it could be it But as it's connected to unit and getting 5v from it I'm not sure...
so if anyone could tell something on that subject I will be grateful.
With wireless aa box I'm going to use 12v adapter; later maybe fitting usb in center console(if it will be 2A)
I can't image good spot for wireless charger
Tell
There are some photographs on the board of people's solutions. I've seen them. Cables and boxes tucked in. It gets round that the car can't get 2amps out of the USB socket of those early units since they were not designed for power hungry smartphones that need 2amps. As said VAG fixed it but we're a bit late to the party.
I use to say in the early days of the Ateca it won't support a smartphone. People were not best pleased with my observations with their brand new car that they wanted to use AA / Car Play on. Even mib3s don't always get the level of charge into Smartphones... then we have the overheating problem with wireless charging. Newer cars have cooling under the phones 🤣. All a bit Heathrobinson. I'm relaxed about it since I use the built in maps. 😂
Tell
Here's one
Poke about in the Google and you'll find more:
Tell
This thread
leonlad
1,155
51
london
This thread
cheers think i have mostly cracked it now, kept saying navigation database not available but there is a tool in toolbox to format the partition for the map data
i should have used the AIO version to begin with
leonlad
1,155
51
london
Must be new having its own. Busy programmers.
These things you only use once unless running a business.
First time i have played around with a harman unit, not sure really. Not sure if the conversion is correct or not as i can't connect to it with vcds CAN is no longer live but neverything else works apart from full link. I do wonder if there are more brand changes needed as the part number still a skoda one.
  • Wow
Reactions: Tell
