Forum member
@STU3Y found an issue with some of the coding instructions in the
guide. The
guide has been updated to reflect this, however if you have previously used the
guide and have come across error code B133914 [009] please carry out the following instruction to correct this:
Connect VCDS to the car and goto Central Electics. Click Security Access and enter code 31347 then click Do It!.
Now go to Adaptations and using the search function type 'Sitz', then press...
