iammooks
1,783
1,172
Discovered that I don't have the M10 triple square I need to get my rear door off, so while I'm waiting for that to arrive, does anyone know if there's a right or wrong way to take the seals off? I need to take it off my old door to put on the new.
Is there any adhesive or do you just push them on?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,227
1,074
Kent
Which seals exactly?
Sent from my SM-S906B using Tapatalk
iammooks
1,783
1,172
This one...
Reactions: BadBoy03
Thai-wronghorse
Dec 3, 2015
2,227
1,074
Kent
The bottom half is pushed onto the edge and upper half has clips.
Carefully prise them out with a trim removal tool as close to the clips as possible or you'll pull them out of the rubber
iammooks
1,783
1,172
Thanks! That's what I thought, but this car has a habit of having me tug away at something when there's a hidden clip somewhere.
Reckon I'll strip the old door once I've swapped them over - the lock in the old one still works, just that the microswitch doesn't recognise that the door's open. Should just need to re-flow the solder and I'll have a working spare.
Now that I've said that though...
Reactions: BadBoy03
Nam-uk
1,173
347
lancashire.
i was going to solder, instead i just cut and used a connector block at least then swapping out switches is less faff, also the switches are handed left and right, as i had a working switch from passenger but it would not fit on the drivers or rear drivers, id lightly re-grease the mech inside there also as the old white grease or what ever they use dry's up putting more stress on the motor probably why the motor fails
MoToJoJo
822
653
Northants
Looking at your tyre wear tells you a lot about your suspension setup...
See, good suspension settings mean even wear across the whole w...wait a minute...
Ok, so we learned two lessons here. 1) I may need a tyre with a stiffer sidewall (this is the outer edge) and/or a degree more static camber. And 2) Yeah, may be an idea to check all the way round the tyre instead of cursory glance when parked up 🤦🏻‍♂️ (only worn like this one part of the tyre, not the whole thin)
Nam-uk
1,173
347
lancashire.
Have all 4 wheels laser tracked i had this done when both front ball joints were replaced as i was getting 4 new tyres just in case that happened.
smutts
373
188
Yup! That is my fronts when the toe is slightly out.
I can't say my Leon is ever gentle on tyres, even when everything is bob on.
And also the rear twist beam setup dates back to the first golf in the mid seventies.
Tyres were much taller then & less bothered with the camber changes inherent with that set up.
The wider, lower tyres of today don't enjoy running with camber.
smutts
373
188
Are those Goodyear Efficient Grips? they do love to roll off the shoulders if the toe-in is a smidge out.
