30psi hot... a tad low but unless the R888R is that fussy about pressure it shouldn't wear like that. Of course this assumes that's relatively consistent all round. Got pictures of the tyre from the other side?
Aside from the tyre, it just screams something wrong with the alignment, be it toe, worn joints etc.
Cheers for replying
30-31 hot. Car felt stable
Others were saying toyo 888 should be run low but I wasn’t down with them being lower.
Something afoot with geometry? Yup. I’m with you on all that.
It’s going back on the ramp soon. We did a check recently on the front end. Anti rill bar bushing was the only thing visible that is near needing replacing.
The other front tyre has worn much better but again there is slightly more wear to the inside edge. Being a clockwise circuit this time out we expected the main wear to be on the front left tyre but it killed the right.
I k no ow there’s big camber in the road at Mallory such as the hairpin which would account for the right front to be abused. Also into start finish it’s off camber left turn. So again could be wearing the right front.
Car was cocking a rear wheel in the hairpin so was pushing through there too.
Maybe this has been a factor?
Badger5 Custom Map + TIP,
