It asks for a security code, what should I enter?It's listed under adaptations in module 17
are you trying with the bonnet open, i did not have to put in any code when i coded mine but things may have changed on later cars.It asks for a security code, what should I enter?
Thanks for this pictures, on the down wheel with ta, ist the Kapazativ function activated / available?
Thanks for the information, I have got formerly the problem that not every steering wheel with Travelassistent is capacativ...Look on the bottom form the steering wheel inside. You see for the Kapazativ a flat module and in the other not. Iff you looking for a steering wheel you can see it at the button from the acc
Is your steering wheel capacativ and have the Travel Assist function?Well, I’ve removed my airbag. As I thought, I don’t have the female plug for the heating fonction on the steering wheel tree but otherwise It seems there would be no problem for installing the capacitive wheel.
However, do guys think that not being able to connect the heating plug would cause trouble with the travel assist feature. View attachment 27289
Please show me those steering wheel. I didn't find the solution without capactive steering wheel.
I coded indeed KLR but also without. There was no difference from the behave off TA
Steering wheel heating not conneted i didnt try. So i dont now iff this needed for that.
Which partnumber has your steering wheel with ta?Please show me those steering wheel. I didn't find the solution without capactive steering wheel.
Zoidberg wheel is BF instead of AM or EP5FA.419.091.AM
No, it’s the original. So far I’ve been unable to acquire one. I thought I was good but the seller went ghost on meIs your steering wheel capacativ and have the Travel Assist function?
Have your car the missing plug for heating Function or the steering wheel?
Can you say me the partnumber of your capacativ wheel?
I know the problem, where / from whom did you order? I found an original steering wheel, but the price is very highNo, it’s the original. So far I’ve been unable to acquire one. I thought I was good but the seller went ghost on me
need to get a new steering wheel for my car, i have not seen my my car recognise trucks and bikes before was this added when travel assist was activated.I made a movie:
Nice movie. Just out of curiosity, what software version are you on? Your graphics looks slightly different to mine (color of the road and other vehicles).I made a movie:
Show a picture of yours? I have to look this one is the first one who came out.Nice movie. Just out of curiosity, what software version are you on? Your graphics looks slightly different to mine (color of the road and other vehicles).
Remover the cover from the steering kolom and tachoframe bij pulling and then turn the wheel 0.25 a turn. Look at the backside you see a hole ( see the movie.) just put a flat screwdriver and push away the little wire you see. Turn the wheel half a turn and do the same. Set steering wheel straight and disconnect the battery. Remove the airbag.
Great video, so I take it that you do not suffer from the "take over the steering wheel" every 10s or so when driving on motor way / high way after installing the capacitive wheel ?I made a movie:
