Sl1ced
797
404
Repaired and re attached my downpipe see how long it lasts. I still hate how loud it is
Reactions: Connor H
iammooks
1,811
1,218
Is this what you're looking for?
Hard to tell, to be honest, but I need the lower cover that covers up the crankshaft, water pump etc. This is roughly what I can see when I have the side undertray taken off:
Does this help?
MoToJoJo
847
685
Northants
Ah right, this bit covers the water pump but doesn't go over the crankshaft pulley, there's a metal plate behind the aux belt pulley that it connects to on mine
iammooks
1,811
1,218
What engine have you got? I'm guessing the ARL?
iammooks
1,811
1,218
Looking at your picture again, it looks like I need that, and the bottom cover - so the whole lot comes in three parts - top, middle and bottom? I'm pretty sure I've only got the top one. I've got the ARL too and I know that the earlier engines (pre-2002 I think) had a different setup with the tensioner, so if yours is about the same age as mine, that cover should fit.
MoToJoJo
847
685
Northants
Mine are late 53/mid 04 plate engines.
Are you missing the part behind the aux belt pulley as well? It hides quite well there with a couple of tabs for bolts sticking up
MoToJoJo
847
685
Northants
Basically the part number is the same for all ARL/ASZ/AXR engines (it's the back plate that changes depending on VIN)
045109147A for the plastic bit
038109175 for the metal part behind the aux belt pulley if you're really unlucky
iammooks
1,811
1,218
This part?
I'll need to have a closer look at what's going on, but I can't see that I'd be missing this part as well, so it sounds like all I need is the part that you've got that goes between the top cover and the bit above.
Sounds like I just need the bit you've got - I really appreciate you going to all this effort - when I've just got this empty space there at the moment I've no idea what's supposed to be there.
Of course, it looks like I need bolts as well...
MoToJoJo
847
685
Northants
This part?
I'd check as it needs to come off when the timing belt gets done
Reactions: iammooks
iammooks
1,811
1,218
It's a relief that I can find the parts online - I'd be very surprised if the bottom cover is missing as well, as I'm sure that would have already caused issues with the accessory belt.
I'd be happy to take your middle cover off your hands. No worries if not though - it looks like I can get hold of one from eBay.
If you know what size bolts I'll need as well, that'd be awesome. Looking around, it sounds like they're 13mm heads, but I can't find anything reliable when it comes to anything else.
MoToJoJo
847
685
Northants
M6x16 bolts. As for the bottom part, famous last words 🤣
Yeah, you can have my spare, includes bolts. DM me
Reactions: Rich.T and iammooks
bruceR
2,572
662
Monifieth, Dundee
So have an issue with my cluster, when ignition on or driving if I bump the top of the dashboard all the warning lights come on and the needles judder down to zero then return back to normal
I’ve taken out cluster to check for loose wiring but none found
Anyone able to help with suggestions
Sl1ced
797
404
I had my lights staying illuminate. The back of the board had a light film on it of water vapour ad what looked like salt residue. Cleaned it off and problem solved
Sl1ced
797
404
So did you remove cluster and split it open then??
Yeah. Remove the needles and it’s quite simple. Just took a soft brush to the board brushed all the crap off left it to air off then put it back in
