If that finishes with 877 or 877A then the unit will not import users Poi's. Seat have acknowledged the issue.
Sadly my unit does end with 877
Hopefully Seat will fix this with a firmware update.
Hi everyone! My unit hardware version is 5QA035858A an my map version 6P091866M (ECE1 2017). This means that I have the MIB2 Standard? Just making sure that I have the right data so I can start reading properly and understanding how to perform the update.
I need to copy the new maps to my existing Seat SD card?
By the way, when updating the maps, is the software/firmware being updated as well?
SCOT. I always say this one now since it's a like for like All Europe bundle. At minute no need to take the zones. It will give you the 5F part number but dont worry and use the workaround.
All European Bundle
Albania*, Andorra, Austria, Belarus*, Belgium, Bosnia and Herzegovina*, Bulgaria*, Croatia, Cyprus*, Czech Republic, Denmark, Estonia*, Finland, France, Germany, Gibraltar, Greece, Hungary, Ireland, Island, Italy, Kosovo*, Latvia, Liechtenstein, Lithuania, Luxembourg, Malta, Macedonia (Former Republic of Yugoslavia)*, Moldova*, Monaco, Montenegro*, Netherlands, Norway, Poland, Portugal, Romania*, San Marino, Sweden, Switzerland, Serbia*, Slovakia, Slovenia, Spain, Ukraine*, United Kingdom, Vatican City
* in parts
http://vw-mapscdn.tdd.adacorcdn.com/DiscoverMedia2_EU_AS_1310_V11.7z
Thank you, Tell for your help. Updated the maps like you've indicated. For ease of reference for future users the steps I took were:
1. Backed up the original SD card on my laptop
2. Formatted the SD card (don't forget to push the card lock mechanism to off)
3. Copied the new downloaded map version to the SD card
4. Replaced /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card
5. edited the /maps/00/nds/dbinfo.txt so that one of the PartNumberX entries correctly has my own part number in it, that is I replaced PartNumber4 from PartNumber4="5F...." to PartNumber4="6P0919866M"
6. long press on the on / off to reboot it so you don't shock the unit by changing the software.
7. Inserted the card into the card 1 slot and all good
Optional
8. Deleted any errors with VCDS
I would be grateful for some advice about updating my maps and which instructions to follow. Here's my current versions. Sorry about the flash from the camera.
I'd prefer a method that doesn't introduce any errors or changes the part number.
Can I go from 0915 to the latest or do i have to go through the intermediate steps ?
Sorry to sound stupid; can you not just buy a newer version genuine SD card on eBay for example to update?
Ah okay thanks for clarifying! I usually use my Apple maps through car play so isn’t an issue for me; was just wondering!No. The card is linked to your car and only one card can be linked. If you already have a card installed, that is linked and therefore buying a new one of EBay will not work.
Just installing a newer card will not link it to the car, hence the workaround which I have personally done 5 or 6 times now with no issues.
