What did you and your MK2 do today?
SpiderWelsh
98
21
Got a speeding letter for doing 41 in a 30 on Saturday.
In my defense, it was a 40 a year ago, thought I was being good only doing 41.
Sent from my Pixel 3 XL using Tapatalk
Kenan
194
73
Gave Betty a clean, was happy with how she turned out considering I've only used soapy water, rinse and dried. (waxed her a few weeks back with Simoniz wax).
Sent from my JSN-L21 using Tapatalk
I assume the red on your car hasn't faded?
Sent from my Mi A1 using Tapatalk
Kenan
194
73
The red has faded, just hard to notice when it's polished and waxed. The bumper doesn't match the shade of the car due to fading.
Looks great
My red car has faded on several panels and looks a different colour from the front to back
saveoursouls
415
234
37
Manchester
Looks great
Cheers.
Have you tried some meguires ultimate compound? It's pretty good for restoring paint.
Brimfull
1,385
418
Wrexham
Fitted a ramair oversized intake kit, to do away with the broken engine cover.
Car now sounds like a hot hatch should do.
On a run of four night shifts now so as soon as Friday comes along, I will degrease the engine bay and tidy it up abit now that you can actually see the engine.
Brimfull
1,385
418
Wrexham
Fitted a set of trusty team heko wind deflectors as the leon is the worst car I have owned for getting your arm soaked when driving with the window down when it's raining.
Reactions: saveoursouls
PaulusB
132
19
Changed my recirc valve to be surprised to find my car had an 8 year old Revision D. Put a revision G on instead as its the better of the two types.
Im sure its not meant to but the old recirc came apart when lifting it out.
What are the symptoms for a faulty one?
Verstuurd vanaf mijn SM-G930F met Tapatalk
PaulusB
132
19
I had a hissing sound under acceleration and all my boost came in one big dollop and went as quickly as it arrived.
Does it then also give a error code?
Brimfull
1,385
418
Wrexham
Yes it can do if its particularly bad, mine didn't and many others don't have codes. It's only when you change it you realise that the old one was faulty.
For the cost of the part and the simplicity of changing it, if you have no records of when it was last changed it makes since to just change it.
Reactions: PaulusB
ZiggyEP3
406
72
UK
Changed the pedals for genuine golf r32 pedals
Before
After
Those are the pedals in my R so I assume they borrowed the parts from the VW line? I have a metal R logo footrest on the left not sure if that's stock or not. I can recommend one as it completes the set just nicely.
Reactions: Yellow fr
Brimfull
1,385
418
Wrexham
Standard mk5 r32 and golf gti pedals. I am slowly adding as many VW golf parts to the interior as I can, as the quality of the seat interior is the one aspect of the car I cant quite get used to.
My last three cars were Mazda, saab and Mercedes so going to the seat interior feels a little like a downgrade.
Reactions: SpiderWelsh
PaulusB
132
19
Changed my DV lot more boost now :) the old one was a G Serie also. This new one is a pierburg part nr 7.01830.13.0 same number as the G revision in the system of the seller, but still looks different don't no why. Before the new one u can here it dumping more air. I cannot see why the old is gone bad the seals are oke. Is the spring maybe wornout ??
New
Old
Brimfull
1,385
418
Wrexham
New
Old
The new one you have Installed is rev d, they last longer than rev g you have removed but the rev g performs better when its working
PaulusB
132
19
Drive likes nuts now. In the article in mygti its the other way around in the design with the colors old the black one new. I called the part shop the say the same I don't understand anymore :)
