Phillips1795
VCDS - How To Guides - MK3 Leon 5F
R4CK5
609
85
I’ve add auto lights to my Leon but the welcome lights to me don’t come on until it’s totally dark!! Is there anyway to adjust them ? I’ve got the vcds software so any help would be appreciated
I would prefer them to come on at dusk light
As you've coded the auto lights there may be the option in the infotainment under the car settings menu. You should be able to choose early mid or late. I say there may be the option as I spec'd auto lights on mine and therefore the menu has always been there for me.
Ash82
148
37
Manchester
It is set to sensitive, but I’ve got an Audi A6 and I unlock this at the same time and the welcome lights come on but not the Leon there must be something in the settings to adjust the sensitivity
R4CK5
609
85
Have you coded the coming/leaving home light thingy separately?
Requin
33
Hi,
I have already post on another topic on this forum.
I don't know if someone got the same default code on the module A5. Since I have coded through VCDS the traffic sign recognition, i have 2 default code:
"1123600 predictive route data B1630 02 [008] - Défaut de signal"
"1123601 predictive route data B1630 02 [008] - Défaut de signal"
Is someone already get this issue on the A5 module. BTW, the traffic sign reco is working well.
Thanks for your help.
iby104
76
10
Hi,
What mofel and year is your car?
Sent from my SM-G930F using Tapatalk
iby104
76
10
I have a leon ST FR from 2016.
Facelift model?
If traffic sign rec means that you get a small maximum speed sign show up(left side) in satnav mode, then on my 2017 fr it came standard.
Can you post your adaptation map?
R4CK5
609
85
Traffic sign recognition should appear in the fis in the gauge cluster as far as I'm aware. The speed limit in the nav is linked to the nav.
iby104
76
10
Im not familiar with traffic sign recognition, is there an addition hardware installed or is it all done by vcd?
Requin
33
Hardware: You need to have the camera below the mirror inside the car (Do you have lane assist and/or light assist option ?)
Software: vcds or obdeleven and follow the tuto.
iby104
76
10
Aah, then i will be of no help. My car is the standard fr tech facelift, the only option i added were the 18" wheels
Requin
33
Hi
The default code (1123600 mentioned before) come from the 5F module. To activate the traffic sign reco, on the tutorial, we have to activate on the 5F module the Byte 24 / bit 7 and it is related to the prédictive route data. I have unactivated it (Byte 24 / bit 7), there is no default code but the traffic sign is not working well and i have an error when i start the engine. Is someone activated Byte 24 / bit 7 for the traffic sign reco ? Thanks
R4CK5
609
85
Welcome lights function was already in the car settings?
Maybe the Audi sensor is just a touch more sensitive then? If you have auto lights and wipers it should work as standard if the car thinks it's dark enough to have lights on.
Ash82
148
37
Manchester
I’m going to go through vcds software again at weekend
Kisszabo
31
Hungary - Győr
Hi everybody! I have a very simple question: Can my Cupra, with this head-unit play videos from USB, or SD? 50A 035 846; HW H24; SW 0245. Thank you for your reply! The fotos are working, but from video files comes only the sound, without picture...
TOLGAHAN KARTAL
Can anyone help me ? I want a open esp sport and esp off but in my code there is no byte 29 how can do?
20EE6A9220212A71007D060801CC240456045400608024F200290020C0
this is my
03-abs
07 codding
long codding code
my car leon fr 2013 1.4 tsi 140 hp
Ash82
148
37
Manchester
I
think I’ve found some hidden codes using a different software odb carista , however my vcds didn’t pick them up? 3 fault codes I’ve cleared them and it seems to have worked, if anyone is having issues like me it could be hidden errors?
