Phillips1795
VCDS - How To Guides - MK3 Leon 5F
ben4012
257
24
Anyone managed to code out auto/comfort rear wipe, by adaptation or long coding. I've tried scores of times in adaptations but can't see a BIT in long coding.
Closest I can see in byte 13 is rear wiper installed. Can anyone point me towards relevant BYTE/BIT.
Deleted member 103408
Sorry i am an obd11 user but have the following coding that you should be able to use via VCDS
Permanently disable comfort rear wiper system
If you do not like that every time you back up the rear wiper is started with this mod you can disable it.
1 - Electronic control module 09-. Code (31347)
2 - Adaptation
3 - Select - wiper
4 - Sub heck -Traenenwischen
5 - Change value on off
ben4012
257
24
2 - Adaptation
3 - Select - wiper
Thanks, I'm actually obd11 as well, looked here for a long coding option as I've tried that adaptation dozens of times. Have you had this work for you?
Had a few seconds so went out to the car.
After you make change you have to go and do a factory reset, either all or Mirrors and Wipers which I did.
Factory reset can be found under car, settings and scroll to the bottom of the list.
_Dejan_
144
66
I have one question. Is possible increase timeout of Stop&Go function(Traffic Jam Assist) from default 3 seconds to higher value(Like 10 or more)?
Thanks for any help.
_Dejan_
144
66
I have additional questions about coding... I have Driving Assistant Pack 4(In our country name so UK maybe have different) There is included:
high beam Assist, Lane Assist and traffic sign recognition + ACC pack (Automatic City brake (Front Assist) with Pedestrian Protection & Stop&Go) + Traffic Jam Assist / Emergency Assist and maybe something else...
My car do not detect standing cars/objects. If car in front move(ACC detect it) before fully stop it is normaly detected but if car in front of me is stopped before ACC detect it car go with full speed forward... Very dangerous...
Im connect OBD11 and check long coding and found some options which are disabled and if someone know what they mean and what happen if I enable them:
Assistent_for_traffic_hold_up - DEACTIVATED
Traffic_jam_dependent_linear_tracking - DEACTIVATED
Reaction_on_standing_objects - DEACTIVATED
pACC_Reaction_to_narrow_places - DEACTIVATED
pACC_Reaction_to_end_of_traffic_jam - DEACTIVATED
-antero-
60
14
Estonia
The version of VCDS (12.xx) that you are using is too old and doesn't have the required .rod files and labels to show the explanations to the fault codes. So first of all get the newest version of VCDS.
The part number of your RVC tells me that you have fitted a highline camera with dynamic guide lines?
The highline RVC requires a calibration process that can be done with VCDS or VCP but you will also need a VAS 6350 board for calibration that you can make yourself. Just google VAS 6350.
Yes camera is highline with dynamic guide lines.
Got myself new VCDS and the missing rod part is okey now. But still cannot code 6c camera module, when I try to insert my code it says Error22: Conditions not correct or request sequence error.
-antero-
60
14
Estonia
I bought it from vwmodul.de :D
Yesterday I sent the camera back and they will try another parametrization. They said that Seat does not support highline camera, so the correct parametrization is bit complicated. But they will try to get it working.
Can and voltage should be good because I can get readings from camera and the module is found with VCDS.
-antero-
60
14
Estonia
I have 2014 FR with Mib1.
There is also one guy from seat-leon.de who has same model and highline camera working even the trailer mode etc works. Told seller about Meich and he said that he will write to him and asks about the parametrization. He knows Meich well, they have been partners for some time. Meich buys some components from him.
I will update my status as soon as possible, but it is going to take at least 8-9 days because I’m on holiday at the moment :)
ukoldschool
382
55
Didn't see this anywhere, but works for me on 2014 Fr184 SC with VCDS 15.7.1
The Mode button changes colour to red at all times with the following change the colour stays the same as all the other buttons (red).
1. Select 09 – Cent. Elect.
2. Select 07 - Coding
3. Select Long Coding and go to Byte 15 and tick the box for 'Bit 7' Drive Select Button w/o Function Light installed
4. Press escape to save and exit
5. Select 'Do it!"
ukoldschool
382
55
2 - Adaptation
3 - Select - wiper
For VCDS 15.7.1 it looks like this:
2. Select 16 – Security Access
3. Input Security Code 31347 Click 'Do it' and 'yes' if it brings up other boxes
4. Select 10 – Adapation
5. Select 'Channel': (4)-Rear Window Wiper-Traenenwischen Heck
6. Change 'Value' on drop down to 'Not active'
7. Select 'Do it'
jellybaby82
11
What type of VCDS interface works on the facelift Leon? Ive got a HEX+CAN lead from RossTech and there are some adaptations Im unable to use. Something about 'unable to support 256 coding', off the top of my head.
VCDS is much better but at a cost.
The support is better, the retrofit functionality is better.
However for day to day usage a large number of VCDS Users also have OBD11.
I am biased as I use OBD11 A lot and so far not found anything I want to do I cant (which would not be true on Carista)
Reactions: jellybaby82
iby104
76
10
I need one that enables autolights on the facelift leon fr 2017 model. To my knowledge, obd11 can only do autolights for the pre facelift
Sent from my SM-G930F using Tapatalk
