2018 / 2019 MIB2 Standard
Ok thanks to Ludo on the
Seat Ateca side of the board here is the link to the Mib2 Standard 2018/2019 download otherwise called 1030. I can't test it myself. This will be for units identified with 6P top left in the normal screen to identify a mib2 standard on a Seat as per the Navigation here maps site.
- Press the “NAV” Button.
- Confirm the “Setup” > “Version information” selection on the display.
6P0 means it's a Seat MIB2 standard don't proceed if that isn't shown.
The download will be EU1 from the file descriptor.
http://vw-mapscdn.tdd.adacorcdn.com/DiscoverMedia2_EU1_2718_1030.7z
It unzips to 12.5 GB (13,528,330,240 bytes) on disk, contains 5,887 Files, 862 Folders. The previous one (0951) unzips to 12.9 GB (13,852,707,481 bytes) on disk and contains 5,886 Files, 861 Folders. So one less folder and one less file and slightly less data that could be rubbish POIs removed or whatever. The missing folder is maps\00\sds\XK which possibly didn't need to be in the other release. Looks like the odd one out... Kosovo seems to have taken a dive in this release or gone somewhere else so I don't think we're worry unduly.
Basically once it's loaded up
we'd expect to see on the second line
1030
& on the third line
ECE1 2018 / 19
I guess it's going to be fine - will be interesting if it doesn't say that.
Post back with your success or otherwise. On a Google I think Ludo has found something that nobody else has posted up yet. Don't forget to do the step (0) above on the thread if you doing the workaround else you will be up that river without a paddle.
