Das Chin
213
12
cleaned it as it was fooking minging. not done for 3 weeks as been in the US with work and weather been appalling when back. its looks white again and not cream ;-)
Miguel 7
R ST
Jan 23, 2017
350
56
29
Fitted some wheel spacers ;-)
Cant sort the photos, will have to twist your heads :D sorry
Glarh
244
21
Bit of a naive question as I'm clueless about this. But are spacers safe to use etc? Was thinking about the idea but I read on a vw forum about a guys wheel coming off. Maybe just being over cautious. Cheers
Miguel 7
R ST
Jan 23, 2017
350
56
29
Well I've never come across any threads with wheels coming off.
As far as I know if they're good quality, with proper, longer bolts then they're safe. If you buy some cheap **** they could crush from what I've read. Other than that I know wheel bearings can wear a bit faster but what is a bit? 10yrs?5yrs? Dont know but thats not something you replace often. Car looks much better thats what I was guided by, but be careful as I've put 13mm in the front and I think any wider could cause some rubbing, unless thats just coz car is slightly lowered.
Miguel 7
R ST
Jan 23, 2017
350
56
29
Also, there's 2 types of spacers, those that you bolt to the wheel hub and then bolt the wheel to the spacer, these are the thicker spacers
And the smaller ones, where you put it all together with just one longer bolt which seems safer to me, but am not a mechanic just saying what I have been reading and what I think :) important to check them after a few miles to see if all good.
Deleted member 103408
And considering the number of major custom companies that make them I am sure they are safe, and there are lots of people on here who have them with no issues. check out this document might give you a bit more info if interested.
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,193
769
69
Edinburgh (Scotland)
Found my jacking pad for the Cupra fitted perfect on the front sill jacking points, but as the rears are a bit wider the pad would not sit on them. With the use of a hacksaw and chisel I made one for the rears from one of my ice hockey pucks, and it fits perfect.
Fraser87
132
Proper link?
The link for the boot struts is taking me to a product that is showing up as only compatible with skodas. Is that correct or am I being redirected somehow to the wrong product.
BenH
658
31
Nottingham
Skoda, Seat, VW and Audi all share parts so yes, that's correct. They're all part of the VAG group(how you pronounce that is entirely up to you)
Fraser87
132
The link in question is sold out. Anyone got another link? So many different ones I'm a little unsure which ones are suitable.
