Tomasz looks good what turbo are you running? Stock internals? Lpfp?
It's "hybrid" turbo (based on my stock unit) modified by Perun Turbo (https://www.facebook.com/perunturbo).
Finishing touches.
Nightmare! Hate people that do that! More than likely the camshaft solenoid mate, check block 93 on VCDS, the specified and actual should match, if they don't then unless the timing has jumped a tooth then its probably the solenoid. The other is probably a system too lean code which could be related.
Looking at selling the FR for a GT86
Cheers mate, it's a Cupra CDL engine. Is the camshaft solenoid the one at the HPFP end of the engine?
Unfortunately I don't have VCDS, only a diagnostic app (Carista).
That's the one. Get yourself a VCDS clone, it'll pay for itself in times like this. Phone apps won't help here unless it can read the camshaft positioning data
