I will try. I hope this works on Seat also.
I have tried to check on my Leon if it's possible but I don't understand what or where is "channel 34", I haven't found it. Any idea?
il have to try this see if it works
Just done it - works as expected - no more yellow button in any mode.
Anymore good coding you wanna share?
Did you get thatt from a webpage or something?
I have over 250 mods via VCDS (Ver 15.7.X). If you need something special, pls ask (type: Lights, BAP, FIS, etc.).
Do you know it's possible via VCDS code reopen mirrors only when you turn on the key on the panel (and not at car opening)? I haven't found solution... thanks!
Mine unfolds mirrors only when I turn key not when unlocking the car.
It came that way, never did any coding.
Mine also unfolds when I unlock the car, pretty dumb if you just forgot something inside.
Exactly, this is the reason, I would like close them when you lock the car but unfold only when you turn the key
