Phillips1795
VCDS - How To Guides - MK3 Leon 5F
kopnyr
64
Nitra, Slovakia
No problemo.
What about new ESP mode:
SEAT LEON 5F - ESP Off (3 Modes) FR, CUPRA
STG 03,
Coding,
Byte 29, change the last to hex-values to 06
Switch off/on the ignition again.
vime81
22
Milan
I have over 250 mods via VCDS (Ver 15.7.X). If you need something special, pls ask (type: Lights, BAP, FIS, etc.).
Do you know it's possible via VCDS code reopen mirrors only when you turn on the key on the panel (and not at car opening)? I haven't found solution... thanks!
riskfactorr
19
Mine unfolds mirrors only when I turn key not when unlocking the car.
It came that way, never did any coding.
vime81
22
Milan
I understood that this is true for 2013/2014 models, on 2015 it unfolds mirrors when you unlock the car, so my question is if it's possible change the behavior via VCDS coding, probably not...
vime81
22
Milan
Mine also unfolds when I unlock the car, pretty dumb if you just forgot something inside.
Exactly, this is the reason, I would like close them when you lock the car but unfold only when you turn the key
