Phillips1795
VCDS - How To Guides - MK3 Leon 5F
vwooks
30
Has anyone managed to turn ESC off with Vagcom?
I don't quite understand how to implement the changes posted earlier in the thread.
Something like this.
Thanks in advance :)
altea-ego
176
CARBON BACKGROUND TO MEDIA SCREEN
Select 5F ( Information Electronics )
Then coding - 07
Then click on "long coding helper"
Go down to byte 17
Un-tick bit 1
Tick bit 2
Exit
Click "do it"
After it says code accepted - come out of all the controllers
Do a system reset - hold power button in for 30 seconds
You now have carbon background to the media unit.
Just tried this, but on mine bit0 was ticked and I ticked bit 1 to get the carbon media screen.
bobajob69
24
Southampton, UK
I have in Southampton. You may recognise me from other thread. Bought sensor and switch too.
Coded blower, red lights, the sensor and the switch although need to make some adjustments as headlights seem to be on most of the time....
LuKnee
Hi, I have just brought my first ever Seat! after getting fed up with Vauxhalls! I love my new car and when I noticed all the mods you guys are doing with VCDS I had to give it ago.
Unfortantly the only things I have been able to acheive is needle sweep! defienatly not worth the money so far!
Everything I want todo is under 09 Cent. Elect. and when I try to go into it I get a "No response from controller" message!
I have a 2014 Seat Leon ST and am using VCDS 11.11.3
Has anyone come across this issue or have any ideas about what todo?
I want to fit a reversing Camera (Which I've already brought) and with being able to get into this it was another waste!
Many thanks in advanced.
Ash
DEAN0
Old Git
Feb 1, 2006
5,382
370
Preston - UK
Ash
It may be the age of your VCDS or the cable you are using - the mk3 leon needs the hex+can cable IIRC
Current VCDS version is 15.7.4 and I know there has been a recent firmware update for the cable too.
LuKnee
Wow thanks for such quick responses, got the correct cable and key is in the right place, wouldn't let me update software earlier, will have to try it again later. Thanks guys.
who.am.i
Leon FR
Jan 23, 2016
392
30
EU
if your vagcom cable is from china/its fake/not geniue ross tech, dont update it.
vag familia
