CARBON BACKGROUND TO MEDIA SCREEN
Select 5F ( Information Electronics )
Then coding - 07
Then click on "long coding helper"
Go down to byte 17
Un-tick bit 1
Tick bit 2
Exit
Click "do it"
After it says code accepted - come out of all the controllers
Do a system reset - hold power button in for 30 seconds
You now have carbon background to the media unit.
Cool - might try this.
I have run mine as low as I dare ( last bar flashing and 0 miles remaining ) and I still can't get the quoted 50ltr in to the tank
Best I have achieved is 48.18ltr at fill up.
Hi, I have just brought my first ever Seat! after getting fed up with Vauxhalls! I love my new car and when I noticed all the mods you guys are doing with VCDS I had to give it ago.
Unfortantly the only things I have been able to acheive is needle sweep! defienatly not worth the money so far!
Everything I want todo is under 09 Cent. Elect. and when I try to go into it I get a "No response from controller" message!
I have a 2014 Seat Leon ST and am using VCDS 11.11.3
Has anyone come across this issue or have any ideas about what todo?
I want to fit a reversing Camera (Which I've already brought) and with being able to get into this it was another waste!
Many thanks in advanced.
Ash
if your vagcom cable is from china/its fake/not geniue ross tech, dont update it.Wow thanks for such quick responses, got the correct cable and key is in the right place, wouldn't let me update software earlier, will have to try it again later. Thanks guys.
Dont know if u can turn off only the light...
vag familia
