Hi wonder if you could
help
I've recently retrofitted the RNS 315 from an RCD 310, fitted the DAB aerial, mic and GPS antenna and coded using a VCDS. All seem to work fine with out much of a
problem but as soon as the ignition has been turned off for about 10 minutes the radio loses all my radio presets and resets itself to Dutch. I tried a couple of times to set the language to either automatic or English, but again once the engines off for a short period the radio reverts back to Dutch. Its the same with the radio presets, i'll set the stations i want, then after the engines off the presets that were on the radio before i retrofitted come back. However i can pair my phone using the bluetooth and save addresses on the Navigation and they come back while the ignition has been off so it's left me baffled.
I'm not sure if this is a
problem with the RNS315 firmware unit or whether i have missed something in the
coding. If it is the firmware i can get this returned for replacement.
My car is a Leon FR 2010 with out the external bluetooth module and has the large white MFD.
This is what i got from the VCDS
VIN: V****************** License Plate:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 1P0 907 115 AD HW: 1P0 907 115 Q
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0303000C18070160
Shop #: WSC 06402 785 00200
VCID: 6DD1D90A745D4E76401-8038
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 163B6012092400FB680B06EB90210081350800
Shop #: WSC 04941 000 00000
VCID: 84071CAE07D72F3E3FF-80D1
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0602
Revision: 00001001
Coding: 0000000002
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 3D71294AACBD1EF6B01-8068
1 Fault Found:
9481200 - Coolant Pressure
B10AB F0 [009] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 46272 km
Date: 2041.14.30
Time: 13:06:49
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 F HW: 5K0 937 086 F
Component: BCM PQ35 M 011 0035
Revision: BC011001
Coding: 46180AF8E037B0C0CA8800808100010442799DA8427D89605C8000000040
Shop #: WSC 04941 123 12345
VCID: 377D3B62868134A66AD-8062
Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 30081 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 06192D
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 5P0 919 475
Component: PARKHILFE 4K H07 0005
Revision: -------- Serial number: 89341019707286
Coding: 000004
VCID: 3A7B2256B59329CE953-806F
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__A0E VW10 HI 1916
Revision: 21014000 Serial number: 003GHPGRYA1K
Coding: 0012357
VCID: 489F489E3B7F4B5E137-801D
Subsystem 1 - Serial number: 6332MTS619571940
Subsystem 2 - Serial number: 6342MTS611501940
Subsystem 3 - Serial number: 6351HTS6B5L2E9KR
Subsystem 4 - Serial number: 6361HTS63TJ0E9KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100826301552
Coding: 108A140002
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F9FD5AF815E2D6DC9-802C
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 951 B HW: 1P0 920 951 B
Component: KOMBI H05 0404
Coding: 410800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2D51190A7CDD8E76001-8078
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 230810F1001228
Coding: E9A07F0640061200000203
VCID: EDD1590AF45DCE76C01-80B8
1 Fault Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 46272 km
Time Indication: 0
Date: 2041.14.30
Time: 13:27:32
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0404
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: EADB52160DB3D94EA53-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668508900
Coding: 010000
VCID: 275DEB225621A426FAD-8072
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 5P0 035 191 G HW: 5P0 035 191 G
Component: RNS315-EU H36 0263
Serial number: SEZAZ2M9175280
Coding: 040004010404000000000008
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2F6D030276D1FC6632D-807A
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
1 Fault Found:
1048659 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 46305 km
Date: 2042.14.00
Time: 12:31:25
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0312
Revision: 12101005 Serial number: 0000977375
Coding: 0012B0
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 7CF7E44EF727D7FEC7F-8029
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
Component: J389__TSG-HR 006 1401
Serial number: 00000005124238
Coding: 000290
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 142 3001
Revision: 00H17000
VCID: 3169057AA8E5EA96249-8064
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0312
Revision: 14101005 Serial number: 0001167918
Coding: 0012B0
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
Component: J388__TSG-HL 006 1401
Serial number: 00000005099763
Coding: 000290
2 Faults Found:
132610 - Motors for Rear Central Locking
B122C 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 61
Mileage: 46272 km
Date: 2041.14.30
Time: 13:21:06
132866 - Switch for Rear Central Locking
B122E 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 101
Mileage: 46272 km
Date: 2041.14.30
Time: 13:21:06
End ---------------------------------------------------------------------
Any
help on this would be greatly appreciated!
Thanks in advance!
