Thanks mate, I'll have to give them a bell!!
Let me get mine done and I will report back. see what you think first.
Here she is, sitting waiting to go up on the ramps
Exhaust system, dont know why it is so quiet, there's hardly anything blocking in the way!
Now here is the resonator section! - not too big!
Had trouble getting one clip off as the bolt was stupidly tight! but finally its all off!
New bit of piping which will go in its place
Cat pipe, 2.75" pipe and theres loads of room for a 3" system
The box has been cut out!
Then here was the last picture i took. this is with the pipe just very tack welded in place to ensure a good fit etc.
After that he took the section off the car, welded it proper and then welded on an exhaust hanger. He followed it up by welding 2 bits of exhaust hanger across both seams to give it some extra strenght. i forgot to take a picture of that bit ill try when i look under the car.
Here is a video of it on tick over + revs. Car had just been run for 20 mins before i turned her on.
Car passed its MOT last Thursday with no problems relating to emissions. how ever it did get picked up for the following :-
Non standard air filter fitted.
Engine cover fitted obscuring some engine components.
Under trays obscuring some underside components.
WTF, think they better get in contact with SEAT and tell them they are building cars wrong??
What sort of places are you guys going to? Any big names or just your local garage?
Sent from my HTC One X using Tapatalk 2
Ive just brought my k1 i also want back box removing and centre section any one got a post code for the place in walsal as im 10 mins from there please lad's.
Have a word with Will at P-torque, they are based in Walsall. Best to give him a call as he's had a couple of issue with his email being hacked.
E-Mail: [email protected]
Telephone: 01902 324 584
I suspect you will end up getting a Stage 1 map at the same time too!
Cheers rob will call tmz
I did look at AMD but they wanted £150!!!
A local garage to me has done babyfaces for £60!
