Jarre, just so you know I have VCDS. If you need it.
How did it run today?
TPM light on dash again, this time I know it isn't the weather, seems like my back right tyre has lost pressure, will check the pressure when I get home from work, thinking of changing all 4 tyres for some good grippy ones!
Sent from my GT-I9300 using Tapatalk 2
Are you hanging around the dealer whilst they look at it or have you left it with them?
Same thing happened to me on Monday the TPM light came on and straight away took it to the petrol station to check pressures. It was the rear drivers side down by 3PSi that mustv set it off. Pumped them all up and reset it, hasnt come back on.
The car is sitting patiently at the garage now ready to have coilovers fitted. Expected to get her back around 5pm I hope but im stuck at work so dont know how much of that promise the mechanic is going to stick to
I already done that but its came back on, so definitely one of tyres are loosing pressure, where you getting your coilovers fitted Khal?
Now at a different dealer, though they have told me 'aftermarket stereo and subwoofer are too many modifications, we really shouldn't even be looking at the vehicle'.
Finally fitted led fogs. Had to get hb4 cancellers though
Resistors worked a treat. Side lights and fogs match now.
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=271014350258
