Cheers mate, make a version using cardboard, you can trim it down untill it perfectly fits and then use it as a template.
Looks nice, what does it sound like? I've been thinking about getting a r tech heat shield and they come with these filters. Will be interesting to see how you get on with it.
The D.K splitter has passed it's testing though, managed to survive over a month on my car
The Mk1 is looking pretty bad now, the laquire has gone a bit cloudy so the Mk2 might have to go on with no Carbon for a while
The Mk1 has had it mate, the big puddle I went through saw to that
I think the the reason the resin was seperating was due to the mix ratio, also I was using an alcohol spray that we use at work to degrease the surface between coat's which I dont think was helping, I changed to the wipes they sell in Halfords and the problem went away.
I saw the pictures unfortunately mate My thoughts were towards V2. Keep us updated with lots of pictures. It makes such a nice addition to the LCR splitter. If only the RS4 splitter wasn't so wide...
Oh, and I didn't see TED sprayed onto the foam filter, like the AKS one
eBay heat shields are crap they don't cover any thing the r tech one makes the unit sealed
How much are they charging for their kit ?
You can get the filter on it's own for £43 on ebay and a shiel will cost you only about £20 (At a guess)
^ defo says about a heat shield for 20quid I'm just saying those 20 quid shields are crap I had one only good bit was I bolted the catch can to it
