you can buy a metal uprated replacement pcv valve..
http://www.creationsmotorsport.com/product-detail.php?pid=15
hi there recently purchased a 180bhp leon cupra but alot of hesitaton could it be anything to do with the turbo actuator or just breather hose or sumthig please help coz am now fed up with car and only had it 2 days!!
Check the pcv breather pipes for splits. The upper one rots from the inside and is fairly easy to spot.
Failing that clean the throttle body and perform a reset with vag com.
Those two are good starting points with the first being the most common.
Interesting thread, did you ever get to the bottom of your problem?
Sounds very similar to the problems that have plagued my car for months. I replaced the DV, N75 and did the N249 bypass which didnt make any difference. It has got worse recently, before it was annoying but didnt really bother me that much. Think mine does the same as the others on here, boosts fine for a bit then the DV lifts despite still being on WOT then like surges and dicks about from there. It idles just fine so I don't think its MAF related?
I can't see any obvious leaks, have been planning to get it leak checked but can't really get at it as the missus needs it for work now. Anyway I have trawled the net and forums for ages but never seen anyone suggesting the PCV valve or the hockey puck.
Where is the hockey puck on an AUQ, and how much is a new one?
