seat leon hesitation
virdi
892
Middlesex
No I haven't done that, I don't think.
Ok stupid question time. Where is the maf and how do I go about testing it?
It sits in between the air box and turbo intake pipe.
You could unplug it and see if it helps. Or you could do a little test with VAGCOM, where you hold the revs at 3000 rpm and check the G/S
adon30
156
Brummm Brummm
So the box from the air filter into the main air pipe? In that case I believe I have already disconnected it prior tithe pcv change. It made no difference during acceleration and I reconnected it promptly. It still generated a couple of fault codes which I cleared.
I can always try it again this evening.
Unfortunately don't have vagcom only have vcds lite.
virdi
892
Middlesex
Vcds lite is the same thing. You should be able to do the check.... It's under engine > measuring blocks. Go up to '003' and the hold the revs at 3000. Your g/s reading should be around 10. If its out by +/- 1, your MAF could be duff.
Note, best to do this check when the car is warmed up.
adon30
156
Brummm Brummm
Well I've done a check. Eventually got the engine running at 3000rpm. Initially the reading was around 10 but I was finding it difficult to hold it steady. Eventually got it sitting bang on 3000rpm and it dropped down to 8.5 and continued to 8. Not conclusive as it did read 10 at times but is it supposed to continue when held?? Engine was all warmed up nice and hot as I did it straight from returning home.
Other thing I had was a fault code yet again. I don't think it's related to this fault as it wasn't there when I had the initial problems with the hoses.
Fault code 18010 - P1602 - Power supply terminal 30. Voltage too low (intermittent)
If it's still thought that it is the MAF what are the part numbers and costs?
virdi
892
Middlesex
Yep. It should it sit at 10 or very close, i.e. no less than 9 and no more than 11.
You could try cleaning the MAF, but if you suspect it's playing up, then it's best to replace it, as they are such a common problem on these cars.
You're looking at between £75-£85 from GSF or Euro Car Parts. I would advise you get a brand new Bosch one. Not a cheapy off eBay.
...as regards to that error code, clear it and see if it comes back. Also google it and see what people have found.
adon30
156
Brummm Brummm
Cheers. It's an expensive part to try though. Luckily ECP have 30% off at the moment so should come in at around £57 ish.
There are two part numbers for the Bosch listed. Both for APP & AUQ engines so not sure what the difference is.
Still not clear as to whether it's the fault or not as when I unplugged it completely it still had the hesitation. Since the PCV change I'm finding it harder at times to make the hesitation appear as sometimes it does accelerate fine.
Are they difficult to clean? I thought they were quite sensitive.
Tr1ck
236
Cornwall
i get a similar problem around 2500-3000rpm when under half throttle. ive replaced the n75 but sill no hope!
some days seems to feel worse than others?
adon30
156
Brummm Brummm
Well MAF replaced and as expected made no difference. Quite an expensive part but now it's ruled out.
Still accelerating like a rocking chair when under boost.
adon30
156
Brummm Brummm
Haven't noticed the idle. Don't sit still for that long.
It's mainly between 2.5 to 4k revs. Someone was on about copper strips in an actuator valve. But not sure what the part is. I've also been told electrical cable connections could cause it.
mk1cupradave
189
Sevenoaks, Kent
Any good garage will be able to smoke test your car. This is what i had done to mine. It will allow you to detect any vacum leaks that you have as well as showing you where it is coming from. After this has been completed you will either be able to replace pipes or atleast eliminate a boost/vacume leak.
If the smoke test doesnt show anything then i would get the car hooked up to vag come and run a number of tests.
adon30
156
Brummm Brummm
Well Smoke test complete. No leaks but at least proves that I put the car back together ok.
They said possibly turbo, I've had someone else say intercooler, someone else say electrics. No idea now.
I reckon if I inflate all my tyres to 32psi exactly that will fix it :blink: It has to be something bizarre :lol:
adon30
156
Brummm Brummm
Noticed that the car got better during the week. Thought it may have been the ecu resorting itself. However on Friday it went back to how it was before. The only difference was that the ambient temperature increased from below 15 to 22 deg c. So car definately runs better when it's cold. Bring on the winter!!
