How much were the adaptors, Greg?
They were £40 from Germany with 2 day delivery
Looks good!
Plastidip is looking like an option for some stuff
Nah not at all mate, bumper off which is about a 5-10 min job, headlights swap, install the 10 to 14 pin Kufatec adapters and bumper on then coded on VCDS. Pretty simple, an hour tops!
Thanks dude, yes they are 100% genuine and came with genuine bulbs & ballasts. They were plug and play using these babies...
Got a link to the adapters? Me wants OEM Xenons now I know I don't have to do any re-wiring.
I'm even considering buying genuine units off Dave, but I think it's about £300 a light
I sure do
http://www.ebay.co.uk/itm/130684895...AX:IT&_trksid=p3984.m1423.l2649#ht_481wt_1417
It states in the item description that these are only available for pre FL. I was the guinea pig for the FL car and they worked fine
The loose wire from the adapters you see in the picture, is the positive feed for the bixenon shutter, all you need to do with that wire is hook it up to the high beam live and you have fully functioning OEM Bi-Xenon headlights
Do you have self leveling or is it still via the manual adjustment dial
