The original air box pipe is the cold air feed it is incorporated into the heat shield there is a notch that it comes through at the bottom
Clever
Tinted my rear lights using the FlyEye Kit and also spent over 4 hours cleaning her..its now raining just as i finish great!
got the link where you got it from mate ?
Sent from my GT-I9300 using Tapatalk 2
Well it wasn't today, but on friday I had the new APR stage 2+ software for the TSI and it is crazy now, 1st, 2nd and half of 3rd are pretty much useless due to wheelspin but when it grips it doesn't half shift! A nightmare in the wet though
Refitted the anti-roll bar and activated the strongest XDS and brake assist settings again ( put everything to standard while it went into Seat ) and it sticks to the road like glue.I was pushing very very hard and it wasn't letting go. The balance is perfect and very predictable, its neutral to oversteery and zero understeer.
If you haven't changed the XDS to the strongest setting in vagcom yet, then do it! (FL only)
On FR's and Cupra' it is set to 0, but on Scirocco R's and ED35's it is set to Strong, so that tells you something about it
Yes it does! GET IIIN free mod coming my way!
Whoops got abit exited
Out of interest, can you change the steering weight? I had the car electrics go all funny 2 weeks back, and the steering hasn't felt right since.
Also on the steering, can you 're-calibrate' it? My car pulls slightly to the left, and the dealership said it's because of the electronic steering, and continually adjusting it back straight should 'teach' the electronic steering.
With regards to tyres.
I had all 4 tyres changed at the same time when I bought the car, and had a 4 wheel alignment done after it on a hunter machine. It was in spec according to that.
The technician also mentioned something about camber of the tyres. Being a German car the camber is setup to pull slightly to the left as they drive on the right hand side of the road. I.E Using tyre camber to counteract the camber of the road. He said it's quite possible they don't bother changing it when they sell them in the UK.
He said the only way to correct it is by doing a trick by sort of shimmying the chassis to adjust for it (which I remember someone posting about on here) but I haven't got around to getting that looked at yet.
Not sure about the electronic steering though as I've been jerking the wheel to correct it when needed and it hasn't been learning jack ****.
