Plan is charge pipe will be extended further forward and dropped straight down (past auxillary belt) which brings it out next to the FMIC inlet
On the other side it will have to loop a little to miss the end of the rad pack then straight up coming out just to the right of the throttle body
I have a weld on MAP sensor boss so this upward run will also double as my MAP pipe too
This shorter route may reduce lag a tiny bit but is being done so i can run an oil cooler in place of the OE passenger SMIC
TBH I am surprised more of us haven't gone and sorted better pipework because the better flowing it is the more efficient and less laggy the system works as a whole..
I'm sure you could fit the core of a cooler and go to a specialist like Hayward & Scott who Maz used for his Hybrid TDI and get them to route a seriously good bit of hard piping for the whole kit to your exact requirements. Of course, not the cheapest option, but I think if your fanatical about getting the maximum from a cooling system it's a brilliant option. I upgraded my fmic kit because I wasn't happy with it and the car certainly performs better for it no doubt about it. BUT if I was being really picky I would go over to Hayward & Scott and see what they can do after seeing Maz's setup.
I have been saying this for awhile that the routing is massively OTT and have been planning on changing it for ages but always had other things to do as well so never got round to it.
Also having moved jobs just over a year ago i no longer have access to a macdaddy TIG welder anymore making it that much more difficult as i cant spend ages fettling as i could before
This is another bit of DIY tuning (following the success of TED and Jamspeed) Ronin style
Hopefully a landrover garage up the road may have a welder they may lend me
