My Black Magic Mk1 LEON Cupra TDI index in 1st post
Feb 22, 2009
3,618
South Wales
JOBS DONE
With the low profile tyres (205/45/16's) I had to put this block under the wheel to get the jack out
REALLY NEED TO LOWER IT NOW
On a side note car turned 115000 today
according to http://www.alloywheels.com/tyrecalc.asp
my speedo will be out now when it shows 70mph I will be doing 65.21
because standard 225-45/17 circumference was 1992.71mm
new 205-45/16 circumference is 1856.37
-136.34mm -6.84%
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
whats the biggest profile you can get / fit for 16s then
im not bothered about speedo , aslong as im doing under what speedo says :)
reasons being mines lowered and wana raise it up abit to avoid all the ice/slush theat gathers inbetween the tracks on roads , i resently scrapped a load , and need to inspect it when possible to see if ive damaged anything
mark keep your eyes peeled for me then
i did txt u yesterday asking for that tyre place u goto , mine are now racing slicks , spend have the journey spinning , and TCS is fighting a loosing battle
Andrewcupra TDI
Apr 30, 2008
3,282
wudnt bother me as such , could work out via satnav then stick to the adjustments etc
aslong as the floor is up away from the ice and **** in the middle of the roads ,
when its snow its not bad , when that bits turned to solid ice , its same affect as concrete , could damage lots of vital buts underneath , £££££
Andrewcupra TDI
Apr 30, 2008
3,282
JOBS DONE
-136.34mm -6.84%
only now seen them pics , them arches have had an argument with your tyres i think:lol:
if u had to use the brick to lower it again , u reckon id have trouble??
