Pyro
bear in mind this is running a stage two revo remap aparently theres something you can use tol change the map????????????
Sunday 25 July 2010 13:56:56
06A 906 032 DE 1.8L R4/5VT 0001
Friday 23 April 2010 21:28:00
06A 906 032 HJ 1.8L R4/5VT 0002
any thoughts i think the top one you can work out torque but dunno??????????
Code:
Group A: '003 Group B: '120 Group C: Not Running
Idle speed Air mass in Throt Angle Ignit Angle Engine Speed Spec Load Curr Load ASR Status
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME 700-6800 RPM 0-399 Nm 0-260 Nm active yes/no TIME
MARKER STAMP /min g/s % °BTDC STAMP /min Nm Nm STAMP
0.5 2520 39.83 31.8 18.8 0.01 2480 399.8 0 ASR OFF
1.61 2840 72.17 100 12 1.11 2680 399.8 180.3 ASR OFF
2.72 3280 106.47 100 8.3 2.12 3000 399.8 247 ASR OFF
4 3800 138.44 100 2.3 3.32 3520 399.8 307.7 ASR OFF
5.13 4320 143.53 100 4.5 4.61 4040 399.8 266.6 ASR OFF
6.36 4800 150.72 100 9 5.74 4560 399.8 272.4 ASR OFF
7.55 5240 157.78 100 9 6.96 5040 399.8 241.1 ASR OFF
8.77 5640 161.5 99.6 12 8.17 5440 399.8 227.4 ASR OFF
10.04 6040 162.83 100 13.5 9.46 5840 399.8 203.8 ASR OFF
11.18 6360 164.39 100 9.8 10.58 6200 399.8 172.5 ASR OFF
12.3 6600 165.69 100 12 11.78 6480 399.8 154.8 ASR OFF
13.5 6840 167.56 100 12.8 12.89 6720 399.8 166.6 ASR OFF
14.78 6720 5.14 5.1 18 14.1 7000 399.8 154.8 ASR OFF
16.01 5640 160.56 100 9 15.48 5520 399.8 207.8 ASR OFF
17.22 5800 163.33 100 5.3 16.61 5720 399.8 198 ASR OFF
18.41 5960 163.58 100 6 17.82 5880 399.8 203.8 ASR OFF
19.52 6120 166.25 100 11.3 19.02 6040 399.8 162.7 ASR OFF
20.81 6240 164.58 100 7.5 20.22 6160 399.8 160.7 ASR OFF
21.94 5000 79.97 32.2 19.5 21.34 5560 399.8 0 ASR OFF
23.13 4880 4.56 7.5 4.5 22.55 4920 399.8 0 ASR OFF
24.14 4560 7.83 7.5 3.8 23.64 4720 399.8 0 ASR OFF
25.32 4280 9.81 7.8 3 24.74 4360
399.8 0 ASR OFF
Code:
Group A: '003 Group B: '115
Idle speed Air mass in Throt Angle Ignit Angle Engine Speed Engine Load Spec. Boost Actual Boost
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar
MARKER STAMP /min g/s % °BTDC STAMP /min % mbar mbar
0.51 1320 7.94 5.9 18.8 0.01 1320 30.8 990 1010
1.63 1360 10.14 7.5 18 1.11 1320 32.3 990 1010
2.73 1360 12.56 9 17.3 2.23 1360 46.6 990 1020
3.9 1400 12.44 9 18 3.33 1360 46.6 990 1030
5.08 1440 12.58 9 18 4.51 1400 47.4 990 1030
6.25 1480 12.19 8.6 18.8 5.65 1440 45.1 990 1040
7.35 1480 11.97 8.6 19.5 6.75 1480 44.4 990 1030
8.46 1520 11.86 8.2 19.5 7.86 1480 42.1 990 1030
9.56 1520 12.11 8.6 19.5 8.96 1520 42.1 990 1030
10.77 1560 12.47 8.6 19.5 10.26 1560 42.1 990 1030
11.88 1560 12.56 8.6 19.5 11.38 1560 41.4 990 1030
13.09 1600 12.64 8.6 19.5 12.5 1600 41.4 990 1030
14.29 1600 12.31 8.6 19.5 13.7 1600 40.6 990 1030
15.59 1600 11.64 8.2 19.5 14.98 1600 37.6 990 1020
16.71 1600 10.78 7.8 19.5 16.13 1600 37.6 990 1020
17.91 1600 10.47 7.5 20.3 17.31 1600 32.3 990 1020
18.92 1600 10.33 7.5 20.3 18.42 1600 32.3 990 1020
20.15 1600 10.11 7.5 20.3 19.53 1600 32.3 990 1020
21.4 1600 10.17 7.5 20.3 20.81 1600 32.3 990 1010
22.54 1600 9.14 6.7 21 21.96 1600 32.3 990 1020
23.75 1600 7.89 5.9 21.8 23.15 1600 27.1 990 1010
24.95 1600 6.39 4.7 21.8 24.35 1600 24.8 990 1010
26.17 1560 5.17 3.5 22.5 25.47 1560 20.3 990 1010
27.37 1520 3.97 2.7 19.5 26.86 1560 12.8 990 1010
28.58 1480 3.58 2.4 4.5 27.97 1520 12.8 990 1010
29.68 1480 4.08 3.1 19.5 29.18 1480 12 990 1010
30.89 1440 3.86 2.7 21.8 30.29 1440 15 990 1010
32.17 1400 3.53 2.4 5.3 31.57 1400 12.8 990 1010
33.31 1320 3.31 2.4 2.3 32.7 1360 12.8 990 1010
34.51 1120 2.86 2 9.8 33.9 1280 12.8 990 1000
35.71 800 2.64 1.6 8.3 35.11 920 13.5 990 1010
37.01 1480 3.94 2.7 4.5 36.32 1360 12.8 990 1000
38.33 1320 3.22 2 5.3 37.73 1400 12 990 1010
39.55 1280 3.97 2.7 20.3 38.94 1280 12.8 990 1010
40.74 1280 14.22 10.2 12 40.15 1240 24.8 990 1000
41.85 1360 17.89 13.7 15.8 41.35 1320 60.9 990 1040
43.04 1520 19.28 13.7 15.8 42.43 1440 66.2 990 1090
44.16 1680 19.81 12.9 18 43.59 1600 63.2 990 1140
45.37 1840 18.81 11.4 19.5 44.78 1760 57.1 990 1130
46.59 1920 14.83 9.8 22.5 45.97 1880 47.4 990 1080
47.73 1960 12.28 8.2 22.5 47.18 1960 37.6 990 1040
49.03 1960 4.69 3.1 1.5 48.39 1960 24.8 990 1020
50.2 1880 5.03 3.5 3 49.59 1920 13.5 990 1010
51.39 1800 4.75 3.5 3.8 50.8 1840 13.5 990 1010
52.41 1440 4.86 3.5 16.5 51.91 1240 13.5 990 1010
53.7 1360 7.11 5.1 17.3 53.02 1360 19.5 990 1010
54.93 1360 8.67 6.3 19.5 54.32 1360 31.6 990 1010
56.03 1360 11.06 7.8 18 55.53 1360 33.8 990 1010
57.24 1400 15.22 11 17.3 56.64 1400 44.4 990 1020
58.45 1480 14.67 9.8 18 57.84 1440 51.9 990 1050
59.74 1480 13.31 8.2 18.8 59.15 1480 50.4 990 1050
60.76 1480 14.36 10.2 18.8 60.25 1480 36.8 990 1030
61.96 1520 15.11 10.6 18 61.36 1520 48.9 990 1040
63.17 1560 17.42 11.8 18 62.58 1560 50.4 990 1040
64.47 1680 19.25 12.9 18 63.79 1640 59.4 990 1080
65.69 1760 11.17 2.7 6 65.16 1720 59.4 990 1110
66.79 1440 15.14 10.2 9 66.19 1320 12.8 990 1030
67.91 1480 17.97 12.9 17.3 67.3 1480 57.1 990 1040
69.13 1560 17.44 11.8 12.8 68.51 1520 61.7 990 1110
70.41 1600 16.61 11 14.3 69.79 1560 57.9 990 1110
71.52 1600 12.81 8.6 19.5 71.02 1600 51.1 990 1090
72.63 1560 3.19 2.4 9 72.03 1600 18 990 1040
73.73 1480 3.22 2 4.5 73.13 1520 12 990 1010
74.97 1440 3.22 2.4 3.8 74.34 1480 10.5 990 1010
76.21 1400 7.06 5.1 17.3 75.61 1400 18.8 990 1010
77.35 1360 10.14 7.5 18 76.75 1360 33.1 990 1010
78.56 1360 10.53 7.5 18 77.97 1360 39.1 990 1010
80.98 1360 9.11 6.7 18 80.29 1360 36.1 990 1020
Friday 23 April 2010 21:35:56
Code:
0.01 1440 22.72 72.5 13.5 0.57 1520 80.5 1450 1100
1.18 1600 27.75 90.6 12.8 1.79 1680 93.2 1520 1250
2.38 1760 34.5 99.6 9 3 1840 102.3 1700 1370
3.59 1960 43.47 100 9.8 4.16 2040 122.6 1910 1550
4.78 2160 59.75 100 5.3 5.34 2320 157.9 2040 1950
5.91 2440 87.78 100 2.3 6.51 2600 191.7 2160 2410
7.01 2760 102.67 100 2.3 7.61 2920 184.2 2200 2300
8.12 3040 103.03 99.2 4.5 8.62 3160 178.2 2200 2250
9.22 3320 116.14 100 2.3 9.93 3480 182 2190 2210
10.5 3640 122.94 100 6 11.03 3760 178.9 2170 2210
11.54 3880 131.83 100 7.5 12.04 4000 173.7 2150 2200
12.64 4160 130.36 100 5.3 13.25 4280 166.9 2090 2120
13.76 4360 137.72 100 6 14.35 4480 164.7 2020 2080
14.88 4600 140.72 100 3 15.56 4720 158.6 1980 2020
16.13 4800 142.72 100 7.5 16.68 4880 154.1 1930 1940
17.27 5000 144.47 100 6 17.77 5080 149.6 1880 1880
18.28 5160 148.67 100 8.3 18.89 5240 148.9 1860 1870
19.49 5320 152.17 100 8.3 20.11 5400 146.6 1830 1830
20.79 5480 151.31 100 9.8 21.48 5560 143.6 1790 1810
21.99 5640 152.17 100 7.5 22.61 5720 142.9 1750 1770
23.21 5760 155.89 100 8.3 23.83 5840 139.1 1720 1750
24.42 5880 154.64 100 9 24.92 5960 136.8 1700 1710
25.53 6000 155.14 99.6 11.3 26.25 6080 133.8 1660 1670
26.91 6120 153.39 100 11.3 27.45 6160 131.6 1640 1650
28.05 6240 154.64 100 12.8 28.64 6280 129.3 1620 1630
29.15 6320 154.33 100 12.8 29.75 6360 126.3 1600 1610
30.27 6400 155.14 100 14.3 30.87 6320 44.4 990 1580
31.52 6240 12.22 8.6 15 32.15 6040 12 990 1050
32.66 5840 12.64 9 12 33.17 5000 12.8 990 1040
33.76 4480 10.75 7.5 3 34.27 4400 12 990 1040
Sunday 25 July 2010 13:54:12
Code:
Group A: '003 Group B: '115 Group C: Not Running
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME
MARKER STAMP /min g/s % °BTDC STAMP /min % mbar mbar STAMP
0.58 2600 33.14 18 26.3 0.01 2200 61.7 990 1120
1.8 1760 16.36 11 22.5 1.18 2320 12.8 990 1100
3 1880 4.36 3.5 14.3 2.4 1840 57.9 990 1070
4.2 1400 15.11 11.4 21.8 3.6 1400 18.8 990 1050
5.49 1560 23.47 19.2 16.5 4.84 1480 65.4 1020 1070
6.61 1800 31.94 100 14.3 6.1 1680 81.2 1380 1150
7.82 2120 42.39 100 12.8 7.24 1960 94 1800 1250
9.03 2480 57.17 100 11.3 8.43 2280 110.5 1990 1410
10.24 2880 78.36 100 10.5 9.64 2680 122.6 2200 1580
11.51 3360 116.06 100 3 10.94 3120 150.4 2350 1920
12.56 3840 136.78 100 3 12.04 3640 188 2260 2270
13.77 4400 142.5 100 5.3 13.15 4120 176.7 2210 2210
14.96 4880 150.5 100 7.5 14.37 4640 167.7 2080 2100
16.07 5240 156.64 100 9.8 15.47 5080 159.4 1960 2000
17.18 5680 161 100 10.5 16.65 5480 154.1 1930 1920
18.29 6040 162.58 99.6 9 17.69 5880 146.6 1890 1850
19.5 6360 164.39 100 13.5 18.9 6200 137.6 1840 1790
20.7 6640 164.58 100 15 20.13 6520 133.8 1790 1740
22 6920 169.14 100 12.8 21.4 6800 130.1 1790 1730
23.11 7160 168.22 99.6 15 22.53 7040 125.6 1790 1740
24.33 6360 9.5 9 16.5 23.72 7200 104.5 1270 1910
25.43 5640 21.25 14.9 3.8 24.92 5640 105.3 1470 1390
26.72 5320 10.86 9 8.3 26.03 5520 11.3 1000 1130
27.95 4920 11.11 8.6 4.5 27.42 5160 12 1000 1070
29.04 4840 34.14 18.4 4.5 28.54 4840 12 1000 1070
30.27 4760 18.86 13.7 36.8 29.66 4800 65.4 1000 1340
31.37 4920 104.97 96.9 18 30.85 4840 84.2 1240 1290
32.66 4920 11.11 6.3 5.3 32.02 5000 133.1 1790 1720
33.88 3960 74.03 63.5 25.5 33.31 4480 12.8 1000 1080
35.07 4120 143.28 100 1.5 34.47 4040 161.7 2140 2040
36.19 4120 13.28 4.3 9.8 35.68 4160 145.1 1000 2460
37.32 4000 5.39 5.5 3 36.79 4040 12 1000 1080
38.66 3800 7.78 6.7 2.3 38 3880 12 1000 1040
39.82 3640 8.28 7.1 2.3 39.21 3720 12 1000 1040
41.03 3520 7.89 7.1 2.3 40.43 3560 11.3 1000 1050
42.12 3400 7.64 6.7 1.5 41.61 3480 11.3 1000 1060
43.39 3080 6.58 6.3 1.5 42.77 3240 11.3 1000 1060
44.53 2720 6.58 5.9 0 44 2920 12 1000 1050
45.64 2440 6.03 5.5 0.8 45.03 2600 12 1000 1050
